Author Topic: Removing old baked on stickers from the windows. Whats the best way?  (Read 1083 times)
Offline jack0
Any ideas don't want to use a scrapper as it might damage the heater elements.
Offline Organisys
  • Old and Slow...
Sticky stuff remover, can get it in most DIY and hardware stores.
Offline monzablue16v
Hairdryer or heat gun and then Meths on a soft rag usually breaks it up :)
Offline jammac
ill second the hair dryer method
ITS A TRAP!
Offline Dec
 :undecided: I just pulled mine off and soapy water + sponged them, didn't work too well so wouldn't recommend it!
Offline fused
Although not on the element sections. I have found a sharp 'stanley' type blade works well with a soapy solution, really does the trick. Just scrap the stuff off!
Offline Mrpug
3rd on the hair dryer or heat gun. Also use alot of patients, I've personally used the heat to pull old tint off my windows. As the sticker get pulled downward try heat and or different combos. Try mayo too, spred it on the sticker itself and let sit for a bit. The oil in the mayo softens the glue and sticker. :wink:
Offline jack0
Heat gun sounds good kill 2 birds with one stone.
1 get the 20 year old stickers off.
2 finally use some of those tools I spent all my money on.
Just need it to stop raining so might be able to get this done in September some time.
