Author Topic: g60 steelies...tyre size?  (Read 1443 times)
Andy Jeffries
« on: 30 January 2008, 16:02 »
ok..currently have 185 60 14's on my mk2 16v...If i was to go for steelies then would I need 195 50 15's or 195 45 15's to keep the rolling radius the same?
also..is it worth getting one as a spare or just keep the original spare?
cheers
Offline fused
Re: g60 steelies...tyre size?
« Reply #1 on: 30 January 2008, 17:13 »
Try this site, loads of info (too much for me!) there is a tyre calculator on there!
http://www.carbibles.com/tyre_bible.html
after you mentioned about spare I just realised, with my 280mm brake upgrade on the front, my tiny gti spacesaver will never fit!
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #2 on: 30 January 2008, 17:24 »
can i ask did you do the 280mm conv. yourself? cos i had major issues tryin to bleed the master cylinder so i went back to standard and now got g60s just sat im my garage rusting :(
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 30 January 2008, 17:45 »
Did you fit the 22mm master cylinder?  I didn't have any problems bleeding my 280s up at all.
What bleeding method did you use?  It can sometimes take a long time to bleed up GTI brakes, what ever method is used.
Offline fused
« Reply #4 on: 30 January 2008, 18:36 »
Sorry my mechanic chucked mine on as I don't have anywhere to do it and it's my daily.
Andy Jeffries
« Reply #5 on: 30 January 2008, 21:17 »
thats a good link...195 50 15's give a minimal difference so thats what im gona go for :)
Offline russ-vdub
« Reply #6 on: 02 February 2008, 15:15 »
yeh had a 22m on there.. bleed them bout 6 times with a pressure bleeder and still pedal straight to the floor :( went through 7 litres of brake fluid, on trade prices so not so bad but a funkin nightmare!
Offline lewis1641
  • stuck in the 90's
« Reply #7 on: 02 February 2008, 16:00 »
i'm on 195 50 15's on the g60 steelies and i use a 185 60 14 spare
