Author Topic: 3-door window seals  (Read 2003 times)
Offline hotrod
3-door window seals
« on: 28 January 2008, 09:10 »
Hi guys, quick question.
Whatever happened to the window seals on the rear side windows on the 3-door. I’ve seen a few 2005 models with seals but the new ones don’t. Any clues. Are they retrofit, has the design changed?
Cheers forum buddies
GTI Edition 30 (1783)   Candy white   KKK04 turbo
Offline TagnuT
  • Edition 30
Re: 3-door window seals
« Reply #1 on: 28 January 2008, 09:43 »
They stopped fitting the seals last year. You notice it more on Candy white cars.
Cost cutting I presume.
Bye Bye Edition 30
Offline SteveS
  • GTI ED30
« Reply #2 on: 28 January 2008, 09:48 »
f**kers
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline gazbutmk5gti
« Reply #3 on: 28 January 2008, 12:18 »
I noticed this when swapping from a 55 plate Gti to the 57 plate ED30, not sure what year they actually stopped fitting them.
Revo stg2+ & lots more
Offline theBatch
« Reply #4 on: 28 January 2008, 13:40 »
can you retro fit them?
Offline joesgti
« Reply #5 on: 28 January 2008, 13:57 »
what are they??  :undecided:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Golfgirl
« Reply #6 on: 28 January 2008, 14:16 »
If you look at this picture of my car you can see it.  At the bottom of the front window there is a black strip, but not at the bottom of the back window.  It ruins the smooth lines and makes the windows look uneven!
Offline carl1
« Reply #7 on: 28 January 2008, 15:15 »
ive had 2 cars with rubber seal and latest without,i think it looks better (mines black tho) and its far less hassle when it comes to waxing not having to be careful getting wax on the rubber
GTI manual PP, now sold  :-(
« Reply #8 on: 28 January 2008, 15:51 »
I used to find on my old car that when I washed it then dried it off, the rubber seals always trapped a little bit of water which would then gradually trickle down the rear panel over the next couple of hours, so prefer no seals thank you
