Author Topic: TURBO  (Read 3489 times)
Offline 20v
TURBO
« on: 25 January 2008, 00:26 »
HI GUYS BEEN LOOKIN ON AN UPRATED TURBO BUT IS THERE MUCH DIFFERENCE BETWEEN THE K03 KO03S AN THE KO4 AN THE PERFORMANCE GAINS YOU WILL SEE AN WOT OTHER MODS WOULD BE NEEDED CHEERS LOZ
Offline S6GTI
Re: TURBO
« Reply #1 on: 25 January 2008, 00:48 »
hi, well i have a gti turbo & my bestmate drives a cupra r, the cupra has the ko4 as standard and is 210bhp on his as standard, the differnce is awsome so i would say that 1, and i think its a direct fit! i am also thinking of a turbo upgrade and that is what i would go for, there was a brand new one on ebay for £550, i know the cupra comes standard with 2 intercoolers and gti's only 1 so might need to uprate the intercooler??? but a chip would prob be a def and also uprating the brakes! So an expensive job but iwould say worth it! Whats your Gti running at the mo?? any other mods??
Offline 1688bran
Re: TURBO
« Reply #2 on: 25 January 2008, 01:11 »
k04 is not a direct fit to the mk4 turbo ... it needs manifold ,custom downpipe , oil&coolant lines,injectors,4bar fr .turbo inlet pipe . movin on to the intercooler the standard gti is smic so it needs to upgrade to fmic .... and an expense labour .
« Last Edit: 25 January 2008, 01:13 by 1688bran »
Offline neg
Re: TURBO
« Reply #3 on: 25 January 2008, 09:33 »
I taje you have yours chipped already as this is obviously the quickest and easiest way to extract some extra power.  KO3s can go upto around 210 as does the K03 I think (might not be quite as good top end with it being smaller), K04 approx 265bhp.
Offline 1688bran
Re: TURBO
« Reply #4 on: 25 January 2008, 13:44 »
k03s with the right mod can go up to around 250 bhp mark ...... for an extra 10-20bhp difference on the k04 is not really worth it cuz i will cost u alot of money to buy parts and labour ....
Offline 20v
Re: TURBO
« Reply #5 on: 25 January 2008, 22:37 »
so you rekon that the k03 is worth stickin with rather than spending the extra money on the k04 because there aint that much init
Offline 1688bran
Re: TURBO
« Reply #6 on: 25 January 2008, 23:04 »
 if u got k03 then i would upgrade to k03s ...... the k03s will hold boost longer than k03 .......
Offline 20v
Re: TURBO
« Reply #7 on: 27 January 2008, 20:56 »
how do you determine if you have a ko3 or a ko3s are there any visual differences
Offline richw911
Re: TURBO
« Reply #8 on: 27 January 2008, 20:59 »
No visual differance which engine do you have what year?
Offline 20v
Re: TURBO
« Reply #9 on: 27 January 2008, 21:17 »
2000 agu
