Author Topic: noise  (Read 1735 times)
Offline 20v
noise
« on: 21 January 2008, 20:39 »
hi im new on here but ive got a 150bhp mk4 golf turbo an i have a problem on idle it sounds as if the thrust bearing on the clutch is noisey but wen i put it into reverse it crunchs just wondering if any one has had this an wether it is the clutch on its way out or gearbox cheers Loz :shocked:
Offline Ashmond
  • Money, b!tches And Boost
Re: noise
« Reply #1 on: 22 January 2008, 08:56 »
Check gearbox oil levels is what I say. Mine crunches into reverse sometimes too but thats because I didnt bleed the clutch when I put it in (or so I been told)
Offline AlanD
  • MK5 2.0T 16v
Re: noise
« Reply #2 on: 22 January 2008, 09:06 »
Mine has crunched now and again when going into reverse, normaly when im in a rush and thrown it into reverse while I have literraly turned the key.
Offline richw911
Re: noise
« Reply #3 on: 22 January 2008, 18:29 »
Does it go quite if you depress the clutch when in neutral?
Offline 20v
Re: noise
« Reply #4 on: 22 January 2008, 19:14 »
 :embarassed:
Offline 20v
Re: noise
« Reply #5 on: 22 January 2008, 19:15 »
it goes all together wiv the clutch down
Offline richw911
Re: noise
« Reply #6 on: 22 January 2008, 19:18 »
defo the thrust bearing then  :angry:
