Author Topic: 16v mk1  (Read 1673 times)
Offline gti fly bye
  • VW MK4 GT TDI, ITS A SMOKEY ALTERNATIVE!
16v mk1
« on: 26 March 2004, 16:27 »
any one ever fitted a 16v in a mk1, jaust about to start one wit a mate, tsr are are suplyin mounts manifold system and loom, any thing else we might need, any problems we may have???
BEAT ANY GTI (TOWING A CARVAN, UPHILL)
Offline mk1
Re:16v mk1
« Reply #1 on: 26 March 2004, 19:20 »
Drops in no problem, use 16v box and fit your 90mm drive flanges to match the shafts or use the 8v box with a 16v pressure plate and a 8v centre. Top and bottom hoses are a mix and match job, I used a modified 16v throttle cable, mk1 8v radiator seems to work ok. What fuel system are you using?.
Steve.
Offline gti fly bye
Re:16v mk1
« Reply #2 on: 26 March 2004, 20:36 »
fule system hey? i have not thought this through, will the 8v fule pumps work? i am keepin it injection, no twin 45's sadly!
Spoke to a gut at TSR but obviously he would only tell me about stuff he could sell me!!!
I'm gonna need afull brake down of what i need here, any one know any sights???
Cheers people ;D
Offline mk1
Re:16v mk1
« Reply #3 on: 27 March 2004, 08:37 »
8v fuel pump works no problem. The main problem is the inlet manifold, the throttle body is on the drivers side so you have to fit the metering unit on the o/s or run a long inlet pipe to the metreing unit on the n/s. Or buy a rare inlet manifold from a 16v scirocco (check parts for sale) Fit the 16v metering unit onto the 8v air box (after cutting the sh!te out of it ;)) and use the stainless injector pipes from the 8v.
Steve.
