Author Topic: LED DASH LIGHTS  (Read 1462 times)
Offline TATS
LED DASH LIGHTS
« on: 14 January 2008, 15:59 »
Hi, am new to the MK2 thing and am after some advice. I've got a couple of blown dashboard display lights and was thinking of putting in leds when i do change them. can anyone tell me what sort of leds i'll need?? Also, where can i get replacement headlamps from, the guy in Halfords assured me that they only had lamps with two connectors as opposed to three, sorry if all this is a bit noddy to most people.
many thanks
tats
 :cool:
STOP IT, YER'LL GO BLIND TO YERSELF
Offline kittie
Re: LED DASH LIGHTS
« Reply #1 on: 15 January 2008, 08:39 »
I got a headlamp on ebay to replace a cracked one, was cheap and in excellent condition!
As for leds you might want to try www.ultraleds.com. You will need to either use 12v leds or use standard leds and solder in a 12v resistor (on either leg) or your leds won't light! Be sure to get the led the correct way round as well, solder pos leg to pos terminal and vice versa.
The wide angled frosted variety are good as they spread the light out (or get normal and file the tip down). They come in a variety of colours and different brightnesses so it's good to try out different ones to get the right look.
The elec window switches are a bastard to do (or I found they were - dificult to get back together properly). I gave up on them and bought new switches! But have experience of this as did all the lights in my fiesta with blue ones, a bit chavvy I know but it was fun to do!
Offline TATS
Re: LED DASH LIGHTS
« Reply #2 on: 15 January 2008, 10:12 »
 :grin:Cheers for the reply kittie
Offline Dubster2
  • Dubs forever!
Re: LED DASH LIGHTS
« Reply #3 on: 15 January 2008, 10:56 »
Should be able to get the headlights from GSF, Euro car parts or the main delaers for standard or other places for crystal ones. Cheaper of course 2nd hand from a breakers, ebay or to a 'wanted' add on here or any other VW forum.
Offline TATS
Re: LED DASH LIGHTS
« Reply #4 on: 15 January 2008, 11:58 »
Its the actual bulb itself that i'm after. my current bulbs have three connector tags on and could only find ones with two tags in halfords.
Offline Agreeable Slick
  • Unit
Re: LED DASH LIGHTS
« Reply #5 on: 15 January 2008, 14:03 »
Go back to halfords, call the guy a dick from a fellow halfords worker (I work for the company), and ask for a 472 bulb. They are the headlight bulbs. (unless you mean a inner spot bulb, in which case they are 453)
Offline TATS
Re: LED DASH LIGHTS
« Reply #6 on: 15 January 2008, 16:44 »
Cheers for that mate, have been back and have now got the right ones. I'm sure it won't be the last noddy question i ask though. Have you any thoughts on leds for my display. Have seen some on t'bay and thought i might give them a whirl :grin:
Offline kittie
Re: LED DASH LIGHTS
« Reply #7 on: 15 January 2008, 20:29 »
What leds have you seen on fleabay? Sometimes they can be a right royal rip off (leds should be pennies)...
Offline TATS
Re: LED DASH LIGHTS
« Reply #8 on: 16 January 2008, 07:58 »
The ones i was looking at were from http://stores.ebay.co.uk/marks-autos.
what do you think?? :undecided:
Offline Dubster2
  • Dubs forever!
Re: LED DASH LIGHTS
« Reply #9 on: 16 January 2008, 14:59 »
I've bought lots of leds from Ultra-leds before. What colour ones are you after?
