Author Topic: Coolant Topup three times since 10th Oct  (Read 1761 times)
Offline keyser
  • They're only the band the beatles could've been.
« on: 08 January 2008, 20:32 »
Since the 10th Oct when I bought my 2 year old GTI, the coolant light has come on three times (every 4 weeks or so) telling me to STOP!  Each time it has been well below the minimum line.  I have topped up and no more problems.  I had a ford focus for 5 years and never topped it up once.  Any ideas what the problem might be?
MK5 GTI, manual, silver, dirty pipes.
Offline TagnuT
  • Edition 30
Re: Coolant Topup three times since 10th Oct
« Reply #1 on: 08 January 2008, 20:47 »
I'd get it booked in at the dealers and checked out. Touch wood, never had to do my ED30 at all and my Mkiv was never touched in 6 years!!!
Bye Bye Edition 30
Offline Russ.C
« Reply #2 on: 08 January 2008, 21:35 »
my brother had this problem with his MK5 2.0 TDI. we were topping it up every 3-4 days though! took it to VW and they checked it over and never found a problem, I think it went in twice, never had anything repaired or replaced and since then its not done it again. Sorry I can't shed any more light on it! Odd  :undecided: :huh:
GTI Edition 30, 3Dr, Manual, Black Pearl, Xenons, Ipod, Highline, Rear Tints & Superchips Bluefin ;)
Offline gazbutmk5gti
« Reply #3 on: 08 January 2008, 22:12 »
Had it on my old 55 plate gti, warning light came on so I topped it up took it into the stealers, they pressure tested it and found no problem and it never did it again in the following 12 months. Probably doesn't help you much though sorry pal.
Revo stg2+ & lots more
Offline makzimum
« Reply #4 on: 09 January 2008, 10:12 »
Hiya,
I've got the same problem on my 05 GTI.  Coolant light came on, topped up, back on within a week or so.  Took it to the dealers and they said it's a problem with the hoses between the rad and the engine.  Where the hoses are close the the engine the heat warps the pipe and breaks the seal slightly.  (Something like that anyway!)  new hoses have been ordered and will be getting them fitted this friday.  I just hope the new hoses aren't subject to the same fault.
Offline saul79
« Reply #5 on: 09 January 2008, 18:26 »
probably the thermo stat housing to the right off the engine (looking from the front) what engine you got in it, i got a thermostat housing for sale if its 2.0 tfsi.your well lucky that ur focus didnt leak any coolant ,i work for fords and they always leak lol
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline NORTHERNER
« Reply #6 on: 10 January 2008, 16:46 »
Get it to the dealers... I had the same issue as makzimum.
All sorted now, along with a fast idle problem that was caused by a vacuum leak... another split pipe... mind you I reckon theseproblems occured when they fit the new engine... car is spot on now and all done under warranty!  Phew!
Mk 5 GTi, Tornado Red, Leather, Xenons, 18" Monza II's, Sunroof, 6CD in Armrest, Winter pack & Tinted Windows... soon to be adding ED30 front spoiler, plus R32 sideskirts... then getting fully colour coded!
New engine fitted when car was at 27k... last one went "noisey".
Offline keyser
« Reply #7 on: 24 January 2008, 17:40 »
B*asta*d coolant light on again.  Topping again and going round to dealers now!
Offline makzimum
« Reply #8 on: 25 January 2008, 08:35 »
Mine has been sorted now - at least I hope it is.  I asked the dealer if they were just replacing the faulty parts with the same (I was worried it would happen again) but they said the part has been re-engineered.  2 weeks since it was done now and all seems ok!  Although I do have to go back for another replacement bit - one of my wing mirror indicators seal is broken and it's full of mould - fortunately it's another warranty job!
Offline aahgolf
« Reply #9 on: 25 January 2008, 13:14 »
I had this a year ago and it was a faulty radiator (found by pressure testing) which was replaced under warranty.
Steel Grey 05 GTI, 3 door, manual, MFD2, 6-CD, sunroof, parking sensors, winter pack/heated seats, lux pack 2, folding mirrors, Koni FSD
