Author Topic: What does this hose do?  (Read 2732 times)
Offline J5H VW
« on: 07 January 2008, 12:50 »
Guys, can hear a noise that sounds like leaking air coming from my engine bay - kind of like the very very early stage of an exhaust going, or a split in a air hose.
When I opened the bonnet, there is a black unit to the left of the power steering reservior.  I think it has two hoses connected to it.
Does any one know what this is?  There is a hose coming off the top of this unit that is about the diameter of a pencil (about 5 - 10mm) that goes a short distance towards the rear of the engine bay and connects to something near (but not related to) the for the coolant tank.  This hose has a split in it.  But does not seem to have anything flowing through it etc.
I know its a bit hard to describe, will see if I can get a photo up.
But in the mean time....any clues as to what this is/ what the unit does?
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline J5H VW
Re: What does this hose do?
« Reply #1 on: 07 January 2008, 13:11 »
Found a pic of an engine bay (i know its a Seat - but its close enough unless someone has one of a mk4 golf i can use!)
See here ->
http://i161.photobucket.com/albums/t212/mkm250680/DSC00086.jpg
The unit I am on about is on just about visible on the left of the photo, between the screen wash and the coolant tank.
What does this do?
Also, the hose that is split on my car is the one that runs from this unit, to just over the power steering tank, its the one that is visible against the coolant tank in the picture.
Once again, anyone got any clues as to what this does?
I knows its not a great description, but any help is much appreciated.
Cheers.
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #2 on: 07 January 2008, 13:26 »
im sure someone will correct me if im wrong but that unit looks like the fuel pump and that lead your showing maybe the power for the pump. does the unit create a ticking sound when the engine is running?
Offline J5H VW
« Reply #3 on: 07 January 2008, 13:59 »
Yes it does make a ticking sound.  But that hose does not have any wires in it!  As I say, the hose is split for the end, and when I pulled it back, there is nothing inside.
I can run the car without this bit connected - but its a bit suspect since you said it could be fuel related.  Reason I say this is that I thought I could smell petrol for the last few weeks, but was never sure.
Any more help guys n girls?
« Reply #4 on: 07 January 2008, 14:35 »
Im convinced that is the fuel pump. Ill have a look on mine when i get in from work tonight and see if i have any wires. That thing you say is split has what appears to be an electrical plug on the end attaching to the pump, and also ribbed plastic casing which wires generally run through. vaccume and fuel etc generally are smoothe rubber hoses so i would presume that this should have wires in it to power the pump.
 :smiley: :smiley:
Offline J5H VW
« Reply #5 on: 07 January 2008, 16:51 »
Cheers mate, much obliged.  I will see if I can work out what this one does too - its the ribbed plastic cased one.
Mysteriously seems hollow though  :shocked:
Offline samy_1800_turbo
« Reply #6 on: 07 January 2008, 18:32 »
the black unit you are talking about is to do with fuel its an evap canister, its to do with emmisions the fuel tank will give off fumes and it cant be vented into the atmosphe so a pipe from the top of the fuel tank runs up to the black canister and then it will let the fume into the inlet mainifol to go into the engine an be burt, the clickin noise is wen its lettin the fumes into the engine. and you say your pipe has split if its the one goin to the manifold it will be suchin in to much air making the noise you discribed. i would get a new pipe for it but i dont fink theres any hurry.
Offline J5H VW
« Reply #7 on: 07 January 2008, 19:02 »
Guess that makes sense for why I can smell fuel also - since the pipe has a split in it.
Is it safe to have this vapour just discharging into my engine bay? :undecided:
« Reply #8 on: 07 January 2008, 19:13 »
actualy thats a good point surspose it mite not be safe lol. you best get a new pipe or put some tap round it untill u can get the pipe
« Reply #9 on: 07 January 2008, 21:35 »
You learn something new every day.
