Author Topic: What does this hose do?  (Read 2733 times)
Offline J5H VW
Re: What does this hose do?
« Reply #10 on: 08 January 2008, 16:42 »
Cheers for the help guys - might have to get some tape out for now till I can get a replacement hose.
Anyone know where I can find more info about this evap canister?  Anyone know the part number by chance?
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline J5H VW
« Reply #11 on: 08 January 2008, 16:59 »
I think you guys are right about all this.  Just found this (c/o VWvortex):
Diagram of fuel system:
http://monty.syr.edu/vw/20vforum/AWDVacDiag.gif
The Key to the diagram is system is found on this link (but also pasted it for convenience):
http://forums.vwvortex.com/zerothread?id=2666114
Key:
1 - Vent line
From gravity valve at fuel tank See "Fuel Tank, Removing and Installing" item no 8. See: Fuel Tank\Service and Repair
2 - EVAP canister
With Evaporative Emission (EVAP) canister purge regulator valve -N80-
3 - Turbocharger
4 - Check-valve
For EVAP canister system
5 - Pressure unit
For Boost Pressure Regulation Valve
6 - Deceleration shut-off valve
7 - Wastegate bypass regulator valve - N75
Valve is activated (pulsed) by the Engine Control Module (ECM)
Checking activation: See Output Diagnostic Test Mode (DTM), activating. Refer to "On Board Diagnostic". See: Computers and Control Systems\Testing and Inspection
8 - Brake booster
9 - Check-valve
For brake booster
10 - Air filter with Mass Air Flow (MAF) sensor - G70 -
11 - Pressure control valve for crankshaft housing ventilation
12 - Combination valve
For Secondary Air Injection (AIR) system
Checking. See: Emission Control Systems\Air Injection\Testing and Inspection
13 - Fuel pressure regulator
14 - Check-valve
15 - Recirculating valve for turbocharger -N249-
16 - Secondary Air Injection (AIR) solenoid valve -N112-
17 - Crankcase ventilation
18 - Check-valve
19 - Charge air pressure sensor -G31- / charge air cooler
20 - Secondary Air Injection (AIR) pump motor - V101 - *
Checking function. See: Emission Control Systems\Air Injection Pump\Testing and Inspection
21 - Vacuum reservoir
The suspects are number 1 and number 2!
