Author Topic: who has a 2lt bottom end gti 8v  (Read 1404 times)
Offline golf mk2 tornado red
  • same s**t just another day
« on: 03 January 2008, 20:56 »
was just wondering .guna find one to rebuild to go with my new head
wots the crack with the oil pump (summat to do with wiering a oil gauge in)
any thing else i would need to do/buy befor i wa to put it in
  cheers guys
Offline dubslug
Re: who has a 2lt bottom end gti 8v
« Reply #1 on: 03 January 2008, 21:23 »
i do, didnt have to wire anything different imusing a pb head from digifant system
1992 pearl grey 8v
« Reply #2 on: 03 January 2008, 21:27 »
sweet thats wot i will be running
oh i met a guy from sheffield who breaks golfs and he said he wired up a oil gauge. he had to   :huh:
anything else you would recommend .wots yours running like.
a friend ov a friend had one chipped and cammed .kept up with scoobies of the mark
  cheers mark
Offline dubslug
« Reply #3 on: 03 January 2008, 22:45 »
he might be on abt vdo gauges so u can see oil temp and pressure???
u will need a 2e dizzy or u could use a pb one with spacer...
there is a breather on front of a 2e block, will need plumbing in or blanking off...
cant really say how its running as i got it back late tonight, i got problem with manifold fouling on the bulkhead
1992 pearl grey 8v
Offline dabill
« Reply #4 on: 04 January 2008, 11:10 »
im running a 2ltre b/e, but shhh!
hasnt been a problem, straight outta a mk3 and straight into the mk2... i say straight... 700£ machining bill on the b/e and had everything skimmed and new seals etc etc, wasnt cheap... either way its fooked now and i want a new engine!
the chap i bought it from had all the work done, but i think the bottom end bearing (if thats what its commonly called) is knocking, and sounds really pants, but performance is still well above a standard mk2 8v digi.
if you get the mk3 block its taller so you may have to chap a small bit off the bottom of your bonnet where the throttle body fouls it..i just smashed the bonnet with a hammer and it dont foul no more  :evil:
noble tuned - and still not fast enough!
« Reply #5 on: 04 January 2008, 17:23 »
only issue with the conversion you might have is the manifold may hit the bulkhead if you go for a 4 branch, a std MK2 8v zaust will fit perfectly though.  I've got an ashley 4 branch on mine now and it still fits fine, though it was like 5" too short so I had to bodge up a joining piece :angry:
« Reply #6 on: 04 January 2008, 18:56 »
been told to use the 2e block
dubslug .vdo gauge now its coming back to me cheers mate
thanks for all advice
cant wait to get my block and start building it (new rings and big ends little ends) oh and my fully recon head .
pushing 164thou now i think its time eh
« Reply #7 on: 04 January 2008, 19:35 »
any 2.0 8v block will do, only issue is some have a different dizzy and s o you have to source & fit a 2e one.  2e is the most straightforward for a digifant MK2 though as the std dizzy etc all plugs into the MK2 loom!  I used all the 2e alternator & coolant setup too.  I had to fit a 2e front coolant flange on the head, and block off the old thin coolant overflow pipe on the top of the rad, I used a short length o pipe with a bolt stuffed in & jubileed in place.
« Reply #8 on: 04 January 2008, 19:49 »
great this is just wot i expected from u guys very plzed thanks alot. just need a block .
got another box caus mines winning in 4th n 5th so guna do the bearings on that to. as mines a daily so its guna be all done over a weekend at work in the garage .so i need everything for that weekend
