Author Topic: Air box drilling  (Read 11502 times)
Offline BobbyT
Re: Air box drilling
« Reply #30 on: 05 January 2008, 21:52 »
i drilled the box in the vr, sounds far better and lets more air into the box, just need to sort a filter out.  :smiley:
Offline bulk66
  • Im broke an it aint a joke!!!!
« Reply #31 on: 05 January 2008, 22:22 »
I drilled my old Vrs air box it sounded ok but when i put an induction kit on oh my god sounded like there was a animal under my bonnet, a big one with pointy teeth... :grin:
Offline capoot
  • Mk1 Skoda Octavia VRS
« Reply #32 on: 06 January 2008, 09:35 »
My Car was stupidly loud....
I did a mini service changing filters etc, opened the air box and the filter in there was tiny!
I put a correct fitment one it, and while i was there i found that my airbox was drilled!!
With the correct filter though it sounds a little quiter!
It is still very loud though!
Offline rsmithone
« Reply #33 on: 23 April 2010, 21:06 »
do you buy the cold air feed or make one also what would happen if you had 2 holes at the front of the box next to the wingside
Offline christomk3gti
« Reply #34 on: 23 April 2010, 21:10 »
you buy one. Ebay sell them cheap.
search cold air feed.
I took the snorkel out of the front of the box (the main air flow feed) and ran my cold air feed in there with gauze on both ends of the cold air feed to stop sh!te getting in.
Black 8v GTI............. Whats a Waffle Valve?
Offline rsmithone
« Reply #35 on: 23 April 2010, 21:20 »
and then run it down where by the front bumper ?
« Reply #36 on: 23 April 2010, 21:23 »
I've run mine out the front of the air box.. then down to the vent in the front bumper (next to the air temp sensor) I only used a small mount of cold feed pipe (which i got from work haha - better quality aswell)
Offline rsmithone
« Reply #37 on: 23 April 2010, 21:28 »
haha sound dont blame you ill give that a go to thanks again
Offline rsmithone
« Reply #38 on: 23 April 2010, 21:30 »
do the gauzes cum with it or do you buy them and put them on yaself
« Reply #39 on: 23 April 2010, 21:34 »
I got mine from work lol...
not 100% sure where u can get them from... but you could use a Sivv... and cut the gauze out of it and fit it to the cold feed pipe with a jubilee or cable ties??
