Author Topic: Air box drilling  (Read 11541 times)
Offline gribsymk3
Re: Air box drilling
« Reply #20 on: 03 January 2008, 22:58 »
does a mk3 8v have a restrictive air intake?? if so how do i remove it? :smiley:
Offline gribsymk3
« Reply #21 on: 03 January 2008, 23:00 »
so the question is do i drill the bottom aswell or just the wing side?? will it suck hot air if i drill the bottom?
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #22 on: 03 January 2008, 23:03 »
Just drill wingside for noise and run a cold air feed to either the back of the box or remove the trumpet in the front of the box and run the feed to this.
Offline Mikester
  • Civic Type R
« Reply #23 on: 04 January 2008, 00:50 »
You mean the air box? or whole air system?
Offline bored_Welsh_lad
« Reply #24 on: 04 January 2008, 07:13 »
mikester i think hes referring to the trumpet section within the airbox, which yeah is restrictive,
I cut out all the fins inside the box and removed the trumpet too  mate... have a look through the guide thats been posted up here
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline gribsymk3
« Reply #25 on: 05 January 2008, 17:21 »
I finally did it this morning after alot of hesitation and im impressed, i only put about 6 20mm holes the wing side only and now when i put the pedal down it growls, i wouldnt say theres any noticable difference in performance tho, worth it for the sound :cool:
Offline Mikester
  • Civic Type R
« Reply #26 on: 05 January 2008, 17:37 »
Drill away the bottom a bit for noise, fit a cold air feed from the bottom splitter up past the alternator, bobs your uncle.
Offline boneybradley
  • Back in a Mk3...
« Reply #27 on: 05 January 2008, 18:23 »
and next week you'll be driling more...the sounds quite adictive  :cool: :cool: (and free :laugh: :laugh:)
hmmmm...mines got more holes than plastic!!...... :smug: :smug:
Offline Mikester
  • Civic Type R
« Reply #28 on: 05 January 2008, 18:28 »
My K&N sounds good. But i hit another bird bradley this morning. lol Pics to come.
kells
« Reply #29 on: 05 January 2008, 18:45 »
blimey....where u going to hit all these birds  :grin: :grin: :grin:
