Author Topic: petrol guzzling  (Read 3567 times)
Offline DriverDude
petrol guzzling
« on: 22 March 2004, 23:51 »
hi, i have a mk2 golf driver (J) 1.8 8v, i have just had it mot'ed and ever since it seems that my petrol seems to be going very quick, i put ?10 in and its like i cant go more than 25 miles,
my petrol gurge seems to be dropping alot faster than it should, do you guys no anyproblem, wothout tank leeks, where this may happen?, maybe the mix or sumthin?
Offline lewis
Re:petrol guzzling
« Reply #1 on: 23 March 2004, 00:31 »
That's a lot of fuel you?re loosing. I get about 100 miles to a ?10 and your only getting a quarter of that. I doubt your car would run well if it was over fuelling that much so I would check for leads first. Have a look under your car to see if there are any obvious drips on the road beneath it, good thing to check to begin with.
turbo
Re:petrol guzzling
« Reply #2 on: 23 March 2004, 01:44 »
dirty air filter worn plugs, dissy cap, rotor arm, dirty fuel filter all cause high fuel consumption!
a fuel leak is number 1 on the list! check the fuel system from the tank all the way to the injectors......any signs of fuel leakage.
are your tyres inflated properly under inflated tyres can cause it to drink fuel and also wear the tyres on the outsides........
if no leaks then it could be the things ive listed......
what is your mfa reading!
is your fuel sender faulty!
the car must have all serviceable things eg spark plugs dissy cap etc in good condition as they could be adding to the problem
if all of the things ive suggested are ok it may be electronic fault, injectors, airflow meter, ecu, all of which can be tested by the dealer..... the injectors and airflow meter can be tested with a multi meter and an haynes manual which tells you how to test them........
« Last Edit: 23 March 2004, 01:55 by vwsystems »
Offline lowgolf
Re:petrol guzzling
« Reply #3 on: 23 March 2004, 13:26 »
I didnt think they did a 1.8 driver in the Mk2? Drivers also didnt think any came with MFA or any electric injection system. It may be your choke, the automatic choke on the piersburg 2E carb is sh!te. If you are running full choke at all times this could cause petrol guzzling. Check your vaccum unit is working on the carb
<br /><br />Yeah!!!
Veedubgt18v
Re:petrol guzzling
« Reply #4 on: 23 March 2004, 17:54 »
yeah they do a 1.8 driver, and yes it is batty pierburg carb!
Offline lowgolf
Re:petrol guzzling
« Reply #5 on: 23 March 2004, 17:57 »
Is it still the 2E carb? Or does it come with a bigger 1?
<br /><br />Yeah!!!
Offline dubslug
Re:petrol guzzling
« Reply #6 on: 23 March 2004, 19:48 »
same carb bigger jets, i no as i have a 1.6 webber and a 1.8 webber at mine. well worth the money and great for fuel, i now get abt 70 miles more for 20 quid  ;D
1992 pearl grey 8v
Offline lowgolf
Re:petrol guzzling
« Reply #7 on: 23 March 2004, 19:52 »
I need a webber carb  :'(
<br /><br />Yeah!!!
Offline dubslug
Re:petrol guzzling
« Reply #8 on: 23 March 2004, 19:53 »
pm me got one going spare
1992 pearl grey 8v
Offline lowgolf
Re:petrol guzzling
« Reply #9 on: 23 March 2004, 19:56 »
you have mail
<br /><br />Yeah!!!
