Author Topic: sub not working  (Read 3468 times)
Offline afcbob
sub not working
« on: 23 December 2007, 21:37 »
I have a 12" that was in my golf did not have it up to high and just stop working nothing no sign of anything wrong.
any way of getting it to work or is it bin job.
Offline dubslug
Re: sub not working
« Reply #1 on: 23 December 2007, 21:50 »
do u have power to ur amp??
fuse in power line??
earth problem??
1992 pearl grey 8v
Offline afcbob
Re: sub not working
« Reply #2 on: 23 December 2007, 21:52 »
yeah amp works fine, tested with 6 x 9's worked ok.
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
Re: sub not working
« Reply #3 on: 23 December 2007, 21:59 »
Possibly a broken connection between box terminals and sub terminals. Failing that maybe toasted voice coils.
Offline afcbob
Re: sub not working
« Reply #4 on: 23 December 2007, 22:00 »
any way of foxing it for just now.
Re: sub not working
« Reply #5 on: 23 December 2007, 22:05 »
wip the sub out the box and connect it direct to the amp using some spare cable. if it works then connectivity is your problem. Toasted voice coils means the death of a sub unfortunatly.
if your gains on the amp are set ok and not clipping; and as you say you werent thrashing it at the time chances are its not the coils.
Offline dubslug
Re: sub not working
« Reply #6 on: 23 December 2007, 22:06 »
open up ur box and see if anythings come off or loose inside....
i assume ur 6x9s worked ok??
1992 pearl grey 8v
Offline vr4000d
Re: sub not working
« Reply #7 on: 23 December 2007, 23:25 »
dodgy connection, broken tinsel lead or blown coils.
so check connections
push the sub in with your hand to see if it moves freely and listen/feel for scraping noises
