Author Topic: bloody oil light  (Read 1852 times)
Offline golf mk2 tornado red
  • same s**t just another day
bloody oil light
« on: 23 December 2007, 19:26 »
bloody buzzer does my napper in mainly when im in 3rd at 2krpm only wen its hot. which switch should i change befor i do the pump   Ã‚£86from vw    and surprisingly £25 from gsf dint think they would do it. oh ive just put a new head on and it seems to do it abit more  :laugh:
Offline Duncanmaclean204
Re: bloody oil light
« Reply #1 on: 24 December 2007, 17:44 »
hi when i bought my mk2 the oil buzzer was doing the same thing and i got told it was a wiring fault, so took it home and had it a week and the engine seized solid and when i stripped it down i descovered that the guy that had it before me put a new sump on it and put to much sealer round the edge, so when he tightened it up the sealer overflowed and went up the oil pick up and chocked, im not saying its wats wrong with yours but i would check 2 make sure your sump is clear and your pickup is not clogged.
Offline Eddie
« Reply #2 on: 02 January 2008, 21:27 »
 :smiley:  Do you have an 8v or 16v?
« Reply #3 on: 02 January 2008, 21:39 »
8v
Offline Simpson
  • one day il learn
« Reply #4 on: 03 January 2008, 17:06 »
change the rear one on the oil cooler and the high pressure switch on the head just to be on the safe side? is it clattering top end when the light comes on, have you tried a good oil flush?  :smiley:
i must buy a new car!
Offline Mannings
« Reply #5 on: 03 January 2008, 18:54 »
yep i've got this problem as well with my valver, happens when i go round corners a bit fast, doesn't stay on too long once the car straightens up, maybe 5 secs. Also i was starting to get some horrible noises from the head (nothing too bad, but not a good look)
Have already done a flush and oil change (carlube) and although it seems to have solved the head noise problems the oil light (and f**kin annoying buzzer) is now coming on a little more than before (and now not only after going round a corner, balls).
Have also had the advice to check the pick up in the sump but am now concerned before i start this that i don't want to fook up the sealing of the sump when i replace it, never about seizing the engine. Will have to look at that quite seriously when i do it.
Also another MK2 owner i know has installed a oil pressure guage so that he can monitor the actual pressure and not rely on the (sometimes dodgy) oil pressure warning sensor.
So basically i'm going to do the sump check (as i have already bought the gasket), then if not fixed will do the oil pressure guage i reckon as i don't fancy doing the oil pump if not required innit.
Will let you know how i get on when i do it, also if you manage to solve it please let me know what your solution was.
« Reply #6 on: 03 January 2008, 19:08 »
think it may be sorted
my dad changed the white one when he had it
ive just changed the blue one and trimmed the wire back and put a new connector on
 fingers crossed eh
oh no noises from the head .i bloody hope not its fully refurbed
« Reply #7 on: 04 January 2008, 17:28 »
white one is the high pressure sender which will sound the buzzer over 2k rpm, the black/blue/brown one is the low pressure one and will flash the light only at idle.
The white sensor should have a yellow wire, the other one is blue :)
« Reply #8 on: 04 January 2008, 18:50 »
fek the things still doin it. guna try a vw white 1
the 1 my dad fitted was a gsf 1
      oh my god
       old vw,s dont die they just do your headin
Offline Simpson
  • one day il learn
« Reply #9 on: 04 January 2008, 20:04 »
i would change the pump if it is still doing it if you plan on keeping the car, i have just bought one with a new sump seal for 50 quid posted. You can buy mine if you want as i dont need it now. Its better than a knackered engine methinks.  :smiley:
