I've got a 280mm set up minus discs and pads here for £60 if you want - means you can buy the pads and discs you want. I run 280mm stoppers and the 22mm master on my G2 Syncro and they are ace - really stand the car on it's nose when needed.
I hust done the 280mm upgrade with the 22mm master cylinder, standard discs and pads. Really happy.... but I had grooved discs and a decent compound pad on my 239mm (think thats right) on my '90 8v, and they were great! So if you can afford it go 280mm, I would go for a set of grooved front discs, a good set of pads, go S.S brake lines all round. I also had by bias valve done a year or so ago which if you suspect it's toast you might as well while the brake fluid is being bleed. Also a half decent brake fluid should be budgeted for. Hope that hasn't given palpatations this close to christmas! good luck
what have u got then? 2 front calipers im presuming??
