Author Topic: Shed-esque Golf2 Syncro  (Read 419910 times)
VeeDubGTI16v
Re: not-a-GTI Golf2 Syncro track shed
« Reply #70 on: 05 May 2008, 15:42 »
how is the power distributed through the 4wd? im guessing its still predominantly fwd?
Offline Horney
« Reply #71 on: 05 May 2008, 16:49 »
Same as the Rallye I believe. A VC that distributes power to the rear when the fronts lose traction.
Nick
Offline Diamond Hell
  • Opinions я Us
« Reply #72 on: 06 May 2008, 00:49 »
Nick's right - power only cuts in at the back when there's slip at the front.  There is a drive out the back of the gearbox which splits the output 50:50 and the viscous coupling (VC) is at the back, right in front of the rear diff.  There is a cunning arrangement of switches on the gearbox that controls a vacuum operated freewheel on the rear drive, too.  By disconnecting the power on gearchanges the danger of transmission wind-up (which the T25 Transporter suffers from, big-style in certain situations) are minimised.
A few features mine now has after a little session today include an oil pressure gauge, an oil temperature gauge and an air:fuel ratio gauge.  It also has a 21W rear foglight on the dashboard, which lights up if there's no oil pressure.  Now THAT's an idiot light  :grin:.
Other bits over the past few days include replacing the front springs with the ones off a Toledo 2.0 8V Sport, which I broke recently.  After a slight  :shocked: moment when I put them on the ride height has now settled at something near acceptable (to me, who doesn't do ride/handling/back damaging 'slammed').  Tracking and camber needs setting now, although according to my calculations (using spirit levels) it's got about -1 on both sides - can't do the tracking quite as easily.
At the moment I'm not happy about the rear end - it's too light and a bit skittish.  As soon as I can I'll get the battery and washer bottle relocated back there, which should even things up quite a lot.
Then it's a cage.
Then bucket seats and proper harnesses..
Then independent throttlebodies and megasquirt.
Or maybe I'll just get on with enjoying it.
Last Friday in June at Castle Combe, Nick?
  • Opinions я Us
« Reply #73 on: 08 May 2008, 09:41 »
Got camber?
Hell yes -2 degrees on both fronts.  It turns in like a hare being chased by a greyhound. Incidentally I did the camber myself - it's basically as far 'in' on the two bolts on the strut as possible.  The tracking was done by Protyre (£26.50).  They also confirmed that I need to rebuild the rear this winter - the passenger side camber is a bit out, which is the perfect excuse for polybushes.
Wires across slam panel = headlight relay loom I made up last night (sorry Beavis, your one got torn down and redone).
Offline dabill
« Reply #74 on: 08 May 2008, 13:51 »
needs spacers, lowering and arches flaaring/rolling.
would look wicked bad then. oh and get some 9'' wide deep dish steels on there too.
then you'll have a real show winner diamond  :rolleyes:
oh yeah, like i said before, buy some back to black! it actually adds bhp!
noble tuned - and still not fast enough!
  • Opinions я Us
« Reply #75 on: 09 May 2008, 21:35 »
Having failed to make it even a little bit attractive I am now posting from outside Blau Ecke in Adenau.  We did have to make an unscheduled maintenance stop in Holland to replace a transfer box flange seal, but were back on the road in about 3 hours.
Touring cars to watch tomorrow and then Sunday and Monday to play  :grin:
Beats buffing.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #76 on: 10 May 2008, 21:24 »
Woo, go TC!
Say hi to Chris from me if you pick this up in time..  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline Horney
« Reply #77 on: 12 May 2008, 09:05 »
Good work DH, Combe in June might well be a goer, I'll have the check my calander.
Nick
  • Opinions я Us
« Reply #78 on: 13 May 2008, 11:14 »
8 laps of lots of fun.  Many hours of working on the car, after it decided to eat bushes.
Topped the 120mph speedo right out on the way home, too.
Full story to follow in due course.
 :cool:
VeeDubGTI16v
« Reply #79 on: 13 May 2008, 14:09 »
i am so jealous right now  :wink: i cant wait to go nurburgringing
