Author Topic: Shed-esque Golf2 Syncro  (Read 419960 times)
Offline Diamond Hell
  • Opinions я Us
Re: not-a-GTI Golf2 Syncro track shed
« Reply #80 on: 14 May 2008, 11:10 »
Full story here.
  • Opinions я Us
« Reply #81 on: 16 May 2008, 13:56 »
Probably my favourite photo from last weekend.
Booked for a power run at InterPro in Thornbury on June 3rd.
Just for interest, really.
Offline Horney
« Reply #82 on: 16 May 2008, 14:16 »
Good read that mate. Nice one.
Nick
  • Opinions я Us
« Reply #83 on: 29 July 2008, 22:31 »
That power run in full:
Diagnosis = crap map.
Only one way around that (in my mind).  Time for independent throttlebodies and Megasquirt:
Got these
Just taken delivery of a box of electronic components that will be built into an ECU shortly.
In the interim I've got an MOT to get through in the next couple of weeks, then the next 'ring trip 12-16th September.
  • Opinions я Us
Re: Cheap-assed Golf2 Syncro track shed
« Reply #84 on: 11 August 2008, 15:57 »
For those who don't Favebook here's a couple of crap laps from inside my car:
Lap 1
Lap 2
This was at the VAG Action Day at Combe on July 26th.
These were shot using my Pentax digital camera and a vacuum mount on the window of the car - much better than any other in-car footage I've ever managed!
Development continues slowly - DannyP showed up and took the MS components away at the weekend 'if I leave this in front of my Dad he won't be able to resist building it'.
After this I need to get a stub-manifold made up to carry the throttlebodies, buy some appropriately-sized silicone hoses and clamps and sort out the loom.  Then it'll probably be live-mapping out on the road before another rolling road session to confirm the mapping.
This will after the trip out to Germany 12-16th September, which will be completed on the existing spec.
« Last Edit: 11 August 2008, 20:50 by Diamond Hell »
Offline Mew
« Reply #85 on: 11 August 2008, 18:57 »
Links don't work matey  :sad:
Offline Mr Blue
« Reply #86 on: 11 August 2008, 19:01 »
Diamond.
How hard is it to convert a 3 door into a syncro? is it just a case of cut syncro floor pan...weld into 3 door floor pan. (use syncro fuel tank and all the other bits)
shorten the prop shaft and wack in a syncro box?
  • Opinions я Us
« Reply #87 on: 11 August 2008, 20:57 »
Links now fixeded
I'm not sure which propshaft you'd be shortening, but no it's not terribly simple!
The Syncro gearbox is only good for up to about 120bhp.  More than that and you need to replace the rivets in the diff and bolt it to stop it being pulled apart.  Alternatively start out with a cable-change gearbox from a Rallye Golf or Passat Syncro, which should be good to 250bhp.
If you think about it you'd be better off going over to Germany and picking up a 3 door LHD Syncro and converting it to RHD - it'll save a lot of MIG wire!
sharpie
« Reply #88 on: 11 August 2008, 22:51 »
yesss  :cool:
boo
Offline Jay
  • balding fat cvnt
« Reply #89 on: 12 August 2008, 20:08 »
Sweet thread  :cool:
When you going to chuck in a VR6 or 1.8T ?  :grin:
