Author Topic: electric problem can any one help  (Read 1767 times)
Offline ian007miles
« on: 12 December 2007, 16:42 »
hi every one , basicly wot it is wen im driving along the temperature gauge is inbetween the 1/4 and the 1/2 but wen i turn my head lights on the temp goes over the 1/2 way mark almost instantly. does any one wot it is or have had the same thing happen to them or is it normal? i no its not that worrying but its enoying, thanx in advance
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline [han]
  • Graphic Designer for Haribo
Re: electric problem can any one help
« Reply #1 on: 13 December 2007, 19:50 »
maybe a bad connection?
my book says the running temp should be just the the left of the light bulb. altho mine runs about there, i do know that the fan kicks in when i sotp the car, so i presume things are ok.
Does your fan kick in at all?
If it varies with just hte lights being turned on it does sound like a conection to me?
« Reply #2 on: 04 January 2008, 17:41 »
bad earth, run a new earth between the side of the head/rocker cover and coil bracket if there isnt one there, later cars got these and its said to effect the dash.  Also pop the clocks out and check for brown wires in the dash clock loom, run a fresh wire from here direct to the chassis :)
