Author Topic: Electric window switches  (Read 2930 times)
Offline JC
  • Back in the North.
« on: 07 December 2007, 11:52 »
 :cry:
u it looks like the leckie windows fitted to my car is an after market  set up as the switches are different. :angry:
They look the same on the front, but the connections are smaller and the mechanism is different inside too.  :rolleyes:
anyone know any more info, or more importantly have a set for sale.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Electric window switches
« Reply #1 on: 07 December 2007, 14:10 »
would it not be possible to take the wiring that is in them, and fit it/doctor it.butcher it to std VW plugs?? theyre used across the board, i got some from an ibiza to fit my sunroof motor switch.. then just use std mk2 switches  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline JC
« Reply #2 on: 07 December 2007, 14:48 »
yeah if i want to re plug 12 wires  :laugh:
 the switches i got fitted are the same from the front, same rocker switch, same picture the lot
just the pin orientation and size is different on the back  :cry:
Offline nealey
« Reply #3 on: 07 December 2007, 16:15 »
Do you have a pic?
I might have the same as you in one of mine and would just like to confirm
Offline JC
« Reply #4 on: 07 December 2007, 17:10 »
not right now,
but the genuine one on the back has 3 pins running diagonally across the switch, and all the pins run top to bottom
on the ones i have fitted they are not all top to bottom
if that makes sense  :laugh:
Offline Ktuludays
« Reply #5 on: 08 December 2007, 16:11 »
is it the GSF aftermarket kit.
mine had this when i bought it
do the contacts at the back of the switch all go in a row rather than staggered?
it is easy to rewire and fit genuine switches
<br /><br />What don\'t kill ya, makes you more strong!
Offline dadrathers
« Reply #6 on: 08 December 2007, 21:36 »
If they are the GSF aftermarket ones then you can buy the switches separately, I believe.
btw - are the GSF aftermarket electric windows any good? Or from the purist point of view should you only ever fit VAG ones????
Offline Jay
  • balding fat cvnt
« Reply #7 on: 08 December 2007, 21:41 »
As purists VAG only. But it depends on how much of a purist you are and how who's cheaper at the end of the day.
« Reply #8 on: 09 December 2007, 03:46 »
The Auto Lift ones are absolutely completely fcuking SHOCKING
TBH.
Quote
Offline JC
« Reply #9 on: 09 December 2007, 14:15 »
right can anyone tell me what wires go where on a standard switch,  as the haynes is pants.
the switch pins are numbered on the back.
obviously you have Earths, live, illumination and then live to power up and down.
any help most welcomed, as its costing me a fortune in fuses  :grin: :grin: :grin: :grin: :grin: :grin: :grin:
and aint got a clue on what kit it is.
the picture on the front of the switch is the same as the genuine VW switch  :undecided:
