Author Topic: Mk3 Golf Stereo wiring and multimeter  (Read 7415 times)
Offline vin297
« on: 26 November 2007, 10:40 »
Im gonna try to install a kenwood stereo into my mk3 golf.  i understand i need to swap the live and ignition live wires.  Can someone help me on how to use a multimeter.  i have just purchased one but havent a clue on how to use it.
Offline peaky83
Re: Mk3 Golf Stereo wiring and multimeter
« Reply #1 on: 26 November 2007, 10:53 »
Pretty open question,
What do you want to do with it?
What purpose have you bought it for?
Offline leegt5
« Reply #2 on: 26 November 2007, 11:35 »
With the multimeter, set the wheel on it to 20v range !!
Then put the black probe onto something that will be your earth like the door hinge and hold it on it then with the red probe touch it on the terminals and what ever terminal you touch and get a reading above 10v that is your permanent live.
Then turn the igintion on and do the same and a different terminal shouls now get a reading as well as the previous one and this will be your ignition live !!
Offline Horney
« Reply #3 on: 26 November 2007, 11:41 »
Perm live should be read and ignition live should be yellow. Earth should be black. These were standard colours introduced for car headunits back in the late 80's.
If you have a new headunit these colours should all match up. In fact it should have the correct connectors in a Golf MKIII but no doubt someone in the past has hacked off the ISO plug. If you want the stereo to NOT go off with the ignition wire the permenant live to bothe the red and the yellow of the headunit.
Nick
Offline twogolfs
« Reply #4 on: 28 November 2007, 11:50 »
Make sure its on the DC range, but 20v is the best one as above.  DC should have a straight line with a dashed line underneath it, AC is the one witht he wavy line.
Switch it on to Ohms range (Omega symbol), any will do.
Put the two probes ends touching
you should get a reading of about 0.1 ohms, thats normal.  This check makes sure that the probes are working correctly first before you start measuring anything.
Then as said above, always put the black one on first and always take it off last.  Trust me, it will take far too long to explain why  :wink:
The new HU should have come with a loom to connect it to the existing car wiring.  Have a look at it and there will be approx 13 wires from memory, the two you are interested in are the Red and the Orange.  If you look closely at these wires there will be bullet connectors on both these wires, a male and a female.  Disconnect both at thiese bullet connectors and swap them over, you will end up with a wire that starts off red and ends up orange and a wire thats opposite to this.
Connect it all up, job done.  15 mins start to finish including programming radio stations is about all it will take, seriously.
Never under any circumstances read the instructions, its a man thing  :grin:
This link might help for the future:
http://www.doctronics.co.uk/meter.htm
Why twogolfs?  Have a wild guess....
Offline Heyho
« Reply #5 on: 28 November 2007, 17:28 »
I don't trust anyone - tell us why.
Offline twogolfs
« Reply #6 on: 29 November 2007, 08:24 »
If you don't know then you dont need to.  Google?
Heres another link that might help with using a MM (google that while you're there)
http://www.umd.umich.edu/casl/natsci/slc/slconline/IDIG/Current.swf
Offline Heyho
« Reply #7 on: 29 November 2007, 17:57 »
I am well aware of how to use a multi-meter, thanks.  And that last link was dealing with current measurement, and therefore totally irrelevant to the above.
The polarity or order of the probes when testing voltage (or current, or resistance) with a multi-meter is of no consequence whatsoever, I just wondered why you thought it was.
Offline twogolfs
« Reply #8 on: 30 November 2007, 16:27 »
The link was aimed at the person who started this link and therefore relevant to them.
If you know as much as you say you would know that it does in fact make a difference.  :wink:
Offline Heyho
« Reply #9 on: 30 November 2007, 21:29 »
Well, you've got me there - I give in.  Now will you tell us?
And for what it's worth, I'd use a test light for simple 12v feed identification. :smiley:
