Author Topic: ive got these codes...  (Read 3074 times)
Offline ian00uk
« on: 23 November 2007, 12:37 »
just plugged my car into vagcom and ive got these codes. Anyone give me any advice?
1) 17608 Boost pressure control valve (n249)- havent a clue what this is.
2) 16684 Random/Multiple cylinder missfire detected
3) Cylinder 1 missfire detected
4)17705 Pressure drop between turbo and throttle valve (check d.v)- i havent even got a d.v!
also did a readiness check and the only thing it failed on was cat monitor failed or not complete, everything else passed
any help people?
Offline richw911
Re: ive got these codes...
« Reply #1 on: 23 November 2007, 12:45 »
What engine If its 1.8T could be your Black plastic Bosh DV? You said you done coil packs Spark plugs mabye?
Offline ian00uk
« Reply #2 on: 23 November 2007, 12:52 »
its a 1.8t aum engine.i have got no dump valve on the car.yeh few months ago had all 4 coil packs changed. spark plugs is a possibilty.
the boost pressure control valve is the one i need to really find out bout.
Offline richw911
« Reply #3 on: 23 November 2007, 12:57 »
I mean the standard Bosh plastic dv. Is the car remapped coz the standard dv internals fail for a pass time. Upgrage it to a forge 007p
 http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=0006&product=FMCL007P
 :wink:
Offline ian00uk
« Reply #4 on: 23 November 2007, 13:02 »
oh rite yeh i presume so. it use to have a atmospheric dv on the car which was taken off. yeh the car is remapped. would getting this sort that problem then. any idea on the boost pressure valve then?
Offline richw911
« Reply #5 on: 23 November 2007, 13:07 »
Yeah i think both those codes relate to the dv. Get some new plugs see if this sorts the misfire bout £20 from halfruds  IIRC.
Komenda
« Reply #6 on: 23 November 2007, 13:19 »
These are all connected to the DV. Its recording a misfire, (no matter how small) as the car isn't getting a consistent air/fuel mix so can't time itself
Offline richw911
« Reply #7 on: 23 November 2007, 13:40 »
Yeah makes sense now you say that  :shocked:
Offline ian00uk
« Reply #8 on: 23 November 2007, 13:44 »
just guna have to book it in somewhere lol
Offline richw911
« Reply #9 on: 23 November 2007, 13:51 »
Just a thought is the car playing up because you say it had an atmospheric dv which will throw up codes, But did you clear the codes after you removed the atmospheric dv??
