Author Topic: ive got these codes...  (Read 3075 times)
Offline ian00uk
Re: ive got these codes...
« Reply #10 on: 23 November 2007, 13:56 »
yeh i reset all the codes then took it for a drive and they all came up again. its annoying. i cant even put my foot down either cuz it stutters and acts like its guna blow my engine so im guessing its to do with the turbo as doesnt do it wen i accelerate gently
Komenda
« Reply #11 on: 23 November 2007, 14:02 »
Your DV has definately split mate, get yourself the Forge jobby and get it sorted ASAP
Offline ian00uk
« Reply #12 on: 23 November 2007, 14:08 »
so how wud the dv cause the car to stutter.if i gota get a new one i wud want one with sum sound saw a forge one with a blow off valve wud that be ok too?
Komenda
« Reply #13 on: 23 November 2007, 14:14 »
The diverter valve regulates the excess pressure from the turbo, if the valve is broken and the excess pressure not regulated it can back up and stall the turbo.
 As your engine relies on the turbo to give its air intake, if the turbo stalls you get inconsistent or no air for the air fuel mix. Hence your stuttery engine under load.
As for the blow off valve, there is no issue in fitting one of these but the turbo works much better if the excess air is fed back to the exhaust side of the turbo, sort of like an anti lag just not as good.
« Last Edit: 23 November 2007, 14:17 by Komenda »
Offline ian00uk
« Reply #14 on: 23 November 2007, 14:17 »
sweet sounds the problem then.il av to order one and see if that works.would the one with blow off valve do the same thing?
Komenda
« Reply #15 on: 23 November 2007, 14:33 »
missed that i modded my post above.
Offline ian00uk
« Reply #16 on: 23 November 2007, 14:43 »
ok mate thanks for your help.il order one and hope that cures it :)
Offline topher
  • Administrator
  • fully functioning
« Reply #17 on: 23 November 2007, 14:58 »
Also check the vacuum line to the DV along it's entire length (its the small braided one). Over time they harden and get brittle from the engine heat.. when it cracks you get problems.
DVs that go PSSHHHFFFT! are about as cool as a Burberry shellsuit.
Offline ian00uk
« Reply #18 on: 23 November 2007, 15:06 »
thats guys will look into it
Offline richw911
« Reply #19 on: 23 November 2007, 15:15 »
Ha ha ha haaa LMFAO  :grin:
