Author Topic: engine STOP comes on saying check coolant ..... coolant is fine  (Read 2619 times)
Offline BobbyT
word up, now i am guessing that a sensor must have gone....maybe in the headder tank?
just want anyinput if anyone has had this before,
start car fine and then after about thirty seconds the stop starts comming up on the dash
Offline Horney
Re: engine STOP comes on saying check coolant ..... coolant is fine
« Reply #1 on: 13 November 2007, 16:28 »
At a guess there will be a sensor in the expansion bottle that reads the coolant level. It's probably that although not sure how you would test it!
That wasn't much help was it?
Nick
Offline BobbyT
« Reply #2 on: 13 November 2007, 18:10 »
^^^ lol  :grin:
Offline Rhyso
« Reply #3 on: 13 November 2007, 19:02 »
sensor is located in the cap i believe although a mate of mine had the whole header tank replaced.
hmmm i'm not much help either really  :undecided:
Offline AlanD
  • MK5 2.0T 16v
« Reply #4 on: 13 November 2007, 19:08 »
What a useless bunch we are !
That wasn't much help either :D
Offline cannybagatuda
« Reply #5 on: 13 November 2007, 19:19 »
if you ignore it,it will go away!
now thats helpful! :grin: :wink:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #6 on: 13 November 2007, 20:22 »
I had this problem, so I changed the header myself.  The part (the whole tank, as you can't get the sensor on its own  (I think)) was under £10, IIRC, & took about 15 mins to swap - Did it in my lunchbreak one day.  The problem came back afterwards as well, but this was because I had too much coolant in.  Check your level is RIGHT ON that 'ridge' that goes around the middle of the tank.  :smiley:
HTH
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline BobbyT
« Reply #7 on: 14 November 2007, 08:58 »
cheers buddy, will have a look today.  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 14 November 2007, 12:33 »
mine does it occasionally, especially in the colder weather... i could cure it by replacing the header tank but i just ignore it and it eventually goes away, bit like an annoying ex.
« Reply #9 on: 14 November 2007, 12:36 »
see? i was right! :grin:
