Author Topic: Water temperature gauge  (Read 1638 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
« on: 12 November 2007, 14:37 »
Where in the engine bay does the gauge get its signal from? Mine is working on and off and its gettin a bit annoying...
Cheers guys
Russ
Offline dubslug
Re: Water temperature gauge
« Reply #1 on: 12 November 2007, 14:41 »
i believe its the black sender on front of engine block, next to the blue one, kinda above oil filter
rik
1992 pearl grey 8v
Offline Conker
« Reply #2 on: 12 November 2007, 14:46 »
If its a 16v, theres three temp senders on the right hand side of the head (near the dizzy).  They are all inter-changeable, so you can just unplug the red/yellow wire (thats the one for the dash gauge IIRC) and pop it on one of the other senders to check if you get a better signal.
Offline russ-vdub
« Reply #3 on: 13 November 2007, 10:12 »
sorry forgot to say its gti 8v
Offline dubslug
« Reply #4 on: 13 November 2007, 14:58 »
its the black sensor then mate
1992 pearl grey 8v
Offline russ-vdub
« Reply #5 on: 13 November 2007, 15:58 »
thanks a bunch, i'll have a fiddle and see if i get a reading! if not then i'll trace the wires back to the dash i suppose? or cud it be the sensor itself playing up?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #6 on: 13 November 2007, 16:12 »
Yep, its the black one. Dont think the sender is expensive from Euro's or GSF?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 13 November 2007, 16:15 »
Maybe I lied!!  251 919 501 D - temp sensor for dash gauge - 2 pin, black  £17.64.....ouch!
Offline dabill
« Reply #8 on: 13 November 2007, 16:22 »
only get the ones from VW, around about the same price (i think) and alot more reliable!
probbaly is the sendor thats faulty... although check the connections and replace the connector if in doubt, do the cheap things first  :laugh:
noble tuned - and still not fast enough!
« Reply #9 on: 13 November 2007, 16:24 »
bridge the pins on the plug, if the gauge shoots to max and the light starts flashing its the sender.
Also the earlier MK2s had the single pin sensor just like the 16v, its threaded into the flange on the front of the head.  Look for a red/yellow wire, thats the gauge feed.  If you do have the single pin jobber, earth it somewhere metal and check the gauge as above.
