Author Topic: what are the best conectors to use when wiring speakers?  (Read 1821 times)
Offline vwjack
thats it really.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: what are the best conectors to use when wiring speakers?
« Reply #1 on: 11 November 2007, 14:28 »
if you can avoid using any...they create resistance so if possible solder all connections..
if not possible, Gold connectors all the way!!
Offline Heyho
« Reply #2 on: 12 November 2007, 21:08 »
Crimp connectors are absolutely fine - the most important thing is to use good quality crimpers - the double width ratchet type are best IMHO.  If you keep it to 1 connector or each end of the wire (ie no joins), then you won't have any resistance problems.
Soldering directly to speaker terminals is Ok, but be careful if they have plastic baskets.
Offline vwjack
« Reply #3 on: 13 November 2007, 00:02 »
thanks for the help guys.
