Author Topic: Pre amp voltages  (Read 4166 times)
Offline JezGTI
Pre amp voltages
« on: 12 March 2004, 00:45 »
Looking at CD/MP3 head units for my MK2.  I may well want to add a sub woofer at some point and an amp, what is the pre amp voltage I should be looking for (they seem to vary from unit to unit).  Don't want to spend much on the head unit (up to ?150), will that get me something half decent? Cheers Jez.
Blue MK2
Re:Pre amp voltages
« Reply #1 on: 12 March 2004, 10:33 »
pre amp volts is the volts that sits on the aux leads going from your headunit to your amp.
The higher the better i think ???
Offline Dizzie
  • Make friends with your fast
Re:Pre amp voltages
« Reply #2 on: 12 March 2004, 16:38 »
some pioneers are 6.5v! my kenwood is 5v
Offline jasonpi
Re:Pre amp voltages
« Reply #3 on: 13 March 2004, 20:28 »
dont know what u can get 4 a 100 quid but bluemk2 is right the higher the better just make sure u draw current from the battery aswell as the ignition barrel
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re:Pre amp voltages
« Reply #4 on: 13 March 2004, 20:40 »
Definitely the higher the better.
Like Dizzies, mine are 5 volt.
You can always by a line driver, which will boost the voltage of your pre-outs, but to be honest, if its just a sub you're powering the voltage (and therefore signal to noise ratio) isn't as key as it would be if you were amplifying front components.
The greatest leveller of them all - the Carousel
Offline Dizzie
Re:Pre amp voltages
« Reply #5 on: 16 March 2004, 19:38 »
always use decent RCA leads and a phat power cable to ensure the best sound. IXOS do some good stuff. about ?40 for their 4 gauge amp wiring kit and about ?30 for a RCA lead.
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
Re:Pre amp voltages
« Reply #6 on: 17 March 2004, 23:32 »
With preamp voltages, higher is better for signal-to-noise.  Think of it this way..
If you were sending 2 volts (old standard) to your amp (or sub) and you're getting a random noise (let's say from the fuel pump) thats about .5 volts (which is a lot, but I digress..), your amp of course is going to boost both up equally aka about 1/5 the signal will be noise (.5/(2.0+.5)), whereas if your preamp is 4 volts it would be 1/9th of the total signal(.5/(4.0+.5)) ...
Now, if you've wired it up so that the system won't catch any noise, then none of this matters.. and and you might want to start competeing, hee.
« Last Edit: 30 March 2004, 00:20 by paladin »
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
