Author Topic: Problem Fitting single CD Player into Mk4 Golf  (Read 4184 times)
Offline spuddaduddadoo
« on: 31 October 2007, 19:40 »
Hello
I've just bought a single CD player for my Mk IV Golf, which looks like this:
My Golf currently has the standard VW Golf stereo with a slot above it, I guess for the CD player to go.
So I managed to ease the pocket/slot above my radio cassette out, and found the socket on the back of the Radio for the CD player, the CD player works and the lights on the CD player illuminate, but, as I slide the CD player back into the slot, the power cuts out.
Firstly, is the CD meant to be on the top of the radio casette, or should the radio/cassette be in the slot above, and sit on top of the CD Player?
Secondly, is there anything else in the slot that should be removed before sliding the CD player into the dash? Is there a knack as to where the wire on the back of the CD player should go as I'm sliding it back in?
Any advise would be greatly appreciated!
Thanks.
Offline Rhyso
Re: Problem Fitting single CD Player into Mk4 Golf
« Reply #1 on: 31 October 2007, 20:45 »
slide the radio out too, then push them both in at the same time.
have a look behind before doing so to see if the CD player is catching on anything.  also do you have the piece that seperates the radio and cd player; it sits between them and is triangle in shape (if i remember correctly!)
« Reply #2 on: 31 October 2007, 20:48 »
Yeah I thought you might say that, no I don't have a seperator , is this important?
Offline Rhyso
« Reply #3 on: 31 October 2007, 20:53 »
yeah it is really otherwise the CD player sits on top and doesn't fit snugly into the DIN slot
have a look at this thread
http://forums.vwvortex.com/zerothread?id=967146
pic 54 shows what it looks like
« Reply #4 on: 31 October 2007, 20:58 »
Hmm, OK
It is possible to buy one of those?
Offline Rhyso
« Reply #5 on: 31 October 2007, 20:59 »
yeah should be; either look on Ebay or pop into your local dealer; can't be more than a couple of quid.
I'd actually try your dealer first as for things like this they tend to be cheaper than Ebay  :shocked:
« Reply #6 on: 31 October 2007, 21:01 »
OK I will probably pop round to my local dealer... thanks.
