Author Topic: cv joints  (Read 3008 times)
free
cv joints
« on: 11 March 2004, 12:58 »
fitted a new drivers side outer 1, 2 days ago. and it started clicking this morning! could it be gone again! the boot hasent come off so the greese ant fell out.
kniterider
Re:cv joints
« Reply #1 on: 11 March 2004, 13:40 »
you should have bought a complete drivve shaft off of me  :P
Offline richandhazel
Re:cv joints
« Reply #2 on: 12 March 2004, 16:13 »
You fitted a new outer CV joint a couple of days ago and its clicking already :o
Something must be wrong...........even a cheap pattern one should last longer than a couple of days.
Thoroughly packed with grease? New circlip? Definately pushed and 'located' onto the shaft?
Offline mk1
Re:cv joints
« Reply #3 on: 13 March 2004, 19:03 »
Are you sure the noise is from the o/s outer joint?.
Steve.
kniterider
Re:cv joints
« Reply #4 on: 13 March 2004, 20:53 »
did you change the right joint??
 ;D
free
Re:cv joints
« Reply #5 on: 15 March 2004, 13:10 »
yeh, turned out to be the inner, just sounded like the outer. prob solved now  ;)
Offline Gambit
Re:cv joints
« Reply #6 on: 15 March 2004, 14:28 »
how hard a job is it to do the inners? mines are bad ::)
Re:cv joints
« Reply #7 on: 15 March 2004, 14:36 »
Unusual for the inners to go before the outers :-\
Blue MK2
Re:cv joints
« Reply #8 on: 15 March 2004, 18:49 »
If you have worn cv joints, does the steering shake slightly too?
CV joints, anyone got a price on the inners and outers, VAG ones.
cheers big ears :P
Offline mk1
Re:cv joints
« Reply #9 on: 16 March 2004, 23:17 »
I have seen worn inner cv joints giving a slight wheel wobble as you accelerate.
Steve.
