Author Topic: Do I just need a oil filter for a oil change?  (Read 2676 times)
Offline mybikeisace
« on: 30 October 2007, 12:55 »
Easy one I know but never changed the oil before. Is the only part I need a new oil filter or do you need a new O ring seal as well? (gsf partno:  11720?)
As for the filter, cant see any on gsf but would euro card parts 501440100 or 501440105 do the job?
(its for a mk3 2.0 8v gti colour concept btw)
While I am on the subject any recommend any new spark plugs as well?
Offline Len
Re: Do I just need a oil filter for a oil change?
« Reply #1 on: 30 October 2007, 12:58 »
Only ever changed the filter myself.
Spark plugs go with standard so you can get them from gsf or Euro along with filter.
www.sas.org.uk
www.the-ace.org.uk
Offline Ridg
  • TDI - Soot Happens!
« Reply #2 on: 30 October 2007, 13:00 »
the filter should come with the o rings you need for it, if they don't they are only going to be pence and worth renewing.
if you're changing the oil via the sump plug you'll want a new seal for that too.
Offline mybikeisace
« Reply #3 on: 30 October 2007, 13:15 »
Is changing the oil via the sump plug not the normal way of doing it? Any idear of what part no the seal for that might be as I can't see it on gsf or euro anywhere.
Offline Ridg
« Reply #4 on: 30 October 2007, 13:22 »
can't really help with the part number at the mo.
through the plug is the normal DIY way, however garages have a big vacuum cleaner type device that sucks the oil out through the dip stick hole, this means you can change the oil hot (which allows for flush etc to be run through)
Offline mybikeisace
« Reply #5 on: 30 October 2007, 13:24 »
ahh cheers. I will give em a ring when I get a chance
Offline mybikeisace
« Reply #6 on: 30 October 2007, 13:38 »
Does a "OIL SEAL-RUBBER RING" sound the right thing?
Offline Ridg
« Reply #7 on: 30 October 2007, 13:47 »
sounds about right, is there anything like sump plug ring?
Offline Pete Taylor
« Reply #8 on: 31 October 2007, 07:36 »
If you buy a new genuine oil filter it will already have the seal built into it. You'll need a new oil filter, a new sump plug and copper washer, an oil filter removel tool (£3 odd from halfrauds), standard plugs will do you for your car, they'll tell you the right ones if you give them the year model and engine code. For oil i'd use 10w semi synthetic for the winter. Whilst you're at it you might aswell get a new pollen filter (essential for the winter to demist the front screen as far as i'm concerned) and a new air filter. If you want to give it a more hardcore service then consider a new distributer cap, rotor arm and ignition leads. Not a fat lot for them and they're a hell of a lot easier to do than changing oil.
www.eurocarparts.co.uk
Your car is the 2.0 AGG engine
Part NO.                                   Part                                                            Price
408770560                       BOSCH SUPER PLUS WR7LTC SPARK PLUGS               Ã‚£2.53 each
501440105                       GENUINE VW OIL FILTER                                        £3.75
507440030                       POLLEN FILTER                                                     Ã‚£5.97
333440010                       GENUINE SUMP PLUG                                              £1.00
360440010                       SUMP PLUG WASHER                                               Ã‚£0.29
404440100                       DISTRIBUTER CAP                                                   Ã‚£7.56
405440010                       ROTOR ARM                                                            £3.70
409440790                       FULL IGNITION LEAD SET                                           Ã‚£16.19
That will give it a hardcore service for not a lot of pennies and will keep it running spot on
« Last Edit: 31 October 2007, 11:54 by Pete Taylor »
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 31 October 2007, 17:34 »
remember the eurocarparts prices are plus the vat!!
