ok as a follow on from my car not starting and then fiding the plugs are bone dry after trying to start the car. ive checked the fuel pump by taking off the incoming fuel line at the fuel rail. when the ignition is turned on fuel pumps through for a couple of seconds and then stops, i was wondering if this is normal or should there be a continuous flow?
also any suggestions as to why fuel os not reaching the cylinders even though there is obviously some amount of fuel pumping in?
thanks. bunter
