Author Topic: Recommend me a sub and amp please.  (Read 4938 times)
Offline gooseuk
  • Diesel is the way forward
Re: Recommend me a sub and amp please.
« Reply #10 on: 27 October 2007, 14:03 »
It is ABSOLUTELY the case that installation and setup is the key.
If you have even half-decent sound up front, the addition of even budget sub-bass can make a system sound so much bigger.  It will even improve the sound quality up front, as you won't be having to boost your bass any more - resulting in clearer midrange from the front.
You definitely don't have to go mad either.  I currently run a JBL GT4 12", powered from a JBL 75.2, in a standard JBL ported enclosure.  Sound quality is good, it integrates well with my front end, and does not sound at all wooly.  They are obscenely cheap now.
http://cgi.ebay.co.uk/JBL-GT4-12-JBL-GTO-75-2-1000W-SUB-2CH-AMP-BOX-WIRING_W0QQitemZ290172100348QQihZ019QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That kit contains everything you'd need, and being a sealed box, would also sound a little more musical.  In terms of value for money, you'd be hard pushed to find anything better value.  Provided you set up the amp properly, you wouldn't be disappointed.
That looks pretty damm good for the price. I dont need anything spectacular so this is right up there.
« Last Edit: 29 October 2007, 12:18 by gooseuk »
Diesel power all the way
Offline b4rks
« Reply #11 on: 28 October 2007, 15:46 »
I used to be big into car stereos, have put various things into various cars with different budgets, MTX, JBL, RF Kicker subs, Phoenix gold, Alpine, Macaudio amps, and more different speakers than i can remember and I agree entirely with what has already been said.
The setup of any system is the key to getting it to sound good.  But with that said the inside of a car is a terrbile place to try and reproduce good quality music.  To even get close to anything that you'd consider awe inspiring on the SQ front you're going to need sound deadening all round, upgraded front speakers, new cabling, a GOOD (and by that read expensive) amp, a sub box built specifically for your car and musical tastes - a sub that also falls into that catagory, a top end head unit, and probably an EQ.
The maximum i think I've spent on any one install was somewhere topping £2500, and even then I wasn't entirely happy with what was coming out..... it's not an easy task.
So getting back on topic, my mk2 has got upgraded but factory sized speakers up front and in the back.  They were however not expensive (JBLs in the back, and vibes in the front) TBH they don't sound a great deal better than the originals in a car with no sound deadening, a stainless exhaust and K&N..... they are running straight off a nakamichi head unit (which admittedly is nice, but again, wouldn't be that much different from any 70 quid sony xplode in actual audio quality), and in the boot is a 12" FLI active sub which I bought from Halfrauds this morning for £120.
It's an all in one unit, comes complete with all the wiring, sealed enclosure so the sound remains tight for rock/pop/classical type stuff, but in fairness did pretty well with a random R&B CD I chucked in to test it.
For the money it's a cracking unit, and if you do only want to spend £150, then I don't think you would be going far wrong.  If you kept the gain set fairly low, but the crossover up a fair way, turned your bass down on the HU so you could put that little bit more volume through your standars, then if you're not a music producer, or audiophile I think you'll be happy enough.
Offline faisalgti
« Reply #12 on: 29 October 2007, 13:04 »
Rockford fosgate are good, you should deffo look into one of their packages
id stay well away from cheeper brands as they, at best sound bad and wooly.
As with most things...what u pay for is what u get
you didnt say what size sub you want either?
Totally agree, im not after massive boxes amps etc i like a decnet sized box with an unbeleivable quality of sound and theres one that does it better than most and that is Rokford. Very expensive as a 100-200w bass box will probably cost around the same as boxes that other manufacturers do at 500-1000w but even at this level id say Rockford would sound better.
If your on a budget though id stay away from Rockford, but if i was you id save up and buy it bit by bit.
Offline joesgti
« Reply #13 on: 30 October 2007, 16:00 »
best sub and amp ive used for reasinable price are alpine type r 12" and a 750w alpine v12 power amp. nice base sound and not muffled realy nice.
my brother is running 4000W amp with an audio bann imortal sub 12", now this is stupid, the sub has a friggin electro magnet in it!!!  :shocked:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Markyp2002
« Reply #14 on: 14 November 2007, 10:12 »
Vibe CBR12 Active. Enough Said!
Offline Guy
« Reply #15 on: 14 November 2007, 21:10 »
exactly!!!!  :wink: :grin: :grin:
Offline Markyp2002
« Reply #16 on: 15 November 2007, 13:32 »
If you want one, i can get them brand spanking new direct from Vibe for £160 (£239 RRP). You can either collect or i can get them delivered anywhere in England, Wales and some parts of Scotland for £15!
Let me know :)
Offline Guy
« Reply #17 on: 16 November 2007, 20:10 »
I guess you didn't get my sense of irony...  :undecided:
I don't want one thanks.... thanks for the offer though.
