Author Topic: Can u connect a sub to a standard head unit and amp on MK5 GTI?  (Read 2637 times)
Offline naresh
hi
I am pretty sure there is an amp already in my 2006 gti under the front passenger seat.
Has any one tried to fit a sub to the stock amp and head unit?
thanks
naresh
Offline joesgti
hummm, dont think they have seperate amps, thought it would just be in the head unit to run the speakers, best putting this question in the mk5 section!  :undecided:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Heyho
You could run a separate amp from the stock headunit to power a sub - you'd need an amp with high inputs, ie that will take speaker level connections.
You definitely won't run an aftermarket sub from the standard headunit.
Offline 08micsta
  • 1982 Mini 1275 Clubby
I dont mean to contradict what you said Heyho. But dependant on what year the Mk5 is will depend on wether it even has an amplifier.
I think 2006 onwards has a built in amp. But look under the driver seat and if there is a stainless steel object there then look in the middle. There should be engraved on it that its a amp. If theres nothing there then there no amp.
I think if I remember correctly you can run a sub from that amp if its there. But not a powerful or killer sub
Mike
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline indublin
  • "Hotel California" forum.... you can log off anyti
Re: Can u connect a sub to a standard head unit and amp on MK5 GTI?
« Reply #4 on: 08 December 2007, 11:20 »
No built in amp on my 2006 MK5
Steel Grey 2006 GTi 3-Door - Monza II's - Tinted Rear Windows - Arm Rest
Offline 08micsta
« Reply #5 on: 08 December 2007, 13:58 »
the site i got my info from is an american based site. so there is a possiblity that what i said may not go for a uk based vehicle
Join our group now!
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« Reply #6 on: 10 December 2007, 20:31 »
depending on the factory radio..u may b able to get hold of a VW lead to plug into one of the spare ports on the rear of the VW radio to give you sum phono pre-outs. but from that point on, it'l b like fitting an aftermarket sub n amp! But best to ask someone in the MK5 section as they may have tried this already and therefore can comment the pro's n con's of this method!?
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
