Author Topic: cant get into first! Is there a cheap fix!  (Read 1887 times)
Offline m4nesh
« on: 08 March 2004, 19:21 »
Howdy
After a long day at work, working my ass off, i reach for my coat grab my pack lunch box and walk towards my car.  Relax in the seat of my lovely digi start the motor, spin some music and then........
the b*st*rd :-X gearbox will not go into first!!!!
I did notice that when I swithced the car off it would go into first and I only knew this as two weeks before the same thing happened and the RAC man diagnpsed this as the clutch cable.  Been fine since then.
Am I correct in thinking a new clutch.  However, the cars only done 70k and had a new clutch three years ago???
OR
Is there some kind of gearbox lever that can break, been told by the mechanic that a mk2s are susceptible for a rod breaking on one of the gearbox levers?
Let me know your thoughts, many thanks in advance to feedback...
Cars costing me too much....
January New Head Gasket ?200 :o
Feb New Clutch cable fitted ?45  :-X
March ......im skint ???
April....gonna sell my GTi to pay for the repairs!!!!!!!!!!!!!!
May ....New corolla (Reliable) :-[
turbo
Re:cant get into first! Is there a cheap fix!
« Reply #1 on: 12 March 2004, 00:26 »
one of the plastic rods may have snapped open bonnet and check them all!
does it go in 1st with the engine off!
if it does it may be a gearbox problem....
or clutch problem........clutch release bearing......?
need proper mecanic to take alook........
until you know what it is it could be a number of things
VeeDubGTI16v
« Reply #2 on: 12 March 2004, 00:29 »
haha thats a classic murray walker quote :)
Offline richandhazel
« Reply #3 on: 12 March 2004, 16:22 »
I'd check the linkage alignment.........quite a common problem and a cheap fix.
Offline m4nesh
« Reply #4 on: 12 March 2004, 18:02 »
Its was preciseely what Richad Hazel has said.  The clutch cable replaced and the cable was catching on something near the clutch pedal..sorted ....and surprisingly my mechanic didn't even charge me cause it was so simple to fix, although I am a bit dubious as to the fact that he replaced the the clutch cable in the first place.
thanks for the feedback all
