Author Topic: OIL LIGHT  (Read 3227 times)
Offline chevychase
OIL LIGHT
« on: 08 March 2004, 18:12 »
can anyone help? driving home tonight my oil light and the buzzer came on for a few mins, oil temp about 110 checked the oil level and its fine but the walter seems very hot and the gage is well over half way. i've not seen that before and the fan works. dose anyone have any ideas your help would be much appreciated
Offline Gambit
Re:OIL LIGHT
« Reply #1 on: 09 March 2004, 09:33 »
are you sure you werent going round a long right hand corner??
the buzzer and light will sometimes come on then for a bit as all the oil is pushed to the left of the sump and the oil pickup gets starved.
aslong as it is not on continuosly u'll be fine
Offline chevychase
Re:OIL LIGHT
« Reply #2 on: 09 March 2004, 11:19 »
i have a 89 16v.i think it only happends when it gets hot and my tapets are a bit loud the last day or two and i wasnt going round a corner
golfvr6
Re:OIL LIGHT
« Reply #3 on: 09 March 2004, 11:23 »
Get your oil pressure tested to be on the safe side.
Offline chevychase
Re:OIL LIGHT
« Reply #4 on: 09 March 2004, 11:29 »
golfvr6. what you telling me? is this bad news and how bad?
golfvr6
Re:OIL LIGHT
« Reply #5 on: 09 March 2004, 11:36 »
it could be the oil pump on the way out, the reason i say that is because you said the tappets have got noisey when the engine is warm, could be start of oil starvation.
could be nothing, but i would get it checked out, otherwise you might not have an engine.
Offline chevychase
Re:OIL LIGHT
« Reply #6 on: 09 March 2004, 11:41 »
Thanks golfvr6. do you no how much and where from. lets hope its not the engine
golfvr6
Re:OIL LIGHT
« Reply #7 on: 09 March 2004, 11:44 »
it won't be the engine if you sort it, you can buy pressure gauges, or a garage should test it for a small fee.
Offline chevychase
Re:OIL LIGHT
« Reply #8 on: 09 March 2004, 11:47 »
golfvr6 what about if it is my engine what will i have to do
golfvr6
Re:OIL LIGHT
« Reply #9 on: 09 March 2004, 11:51 »
It won't be the engine, the oil pump circulates the oil, if oil starvation is the problem, chances are the pick up strainer is blocked.
Don't run the car until you are sure the oil pressure is ok, that way you won't damage the engine if the oil pump is suspect.
