Author Topic: Stock stereo, turn-on lead question.  (Read 2041 times)
Offline Madmax
« on: 12 October 2007, 22:16 »
Hi,
Need to connect the blue turn-on lead to somewhere to trigger it to turn on/off with the engine, stock stereo's don't
come with one so where's the next best place?
Thanks.
« Last Edit: 13 October 2007, 00:29 by Madmax »
Offline Heyho
Re: Stock stereo, turn-on lead question.
« Reply #1 on: 13 October 2007, 08:59 »
Do you mean the remote switch on for an amp or electric aerial?  What car is it?
Offline Madmax
« Reply #2 on: 13 October 2007, 10:31 »
Hi,
The blue wire on the stereo, which doesn't come on stock head units i've heard.
It's for a Golf Mk4.
Offline jaybee
« Reply #3 on: 21 October 2007, 10:26 »
Is this the blue one with the little gold squares on it....
I was just about to ask what that was for....
Is it the same on a mark 3....
Offline tommk3cab
« Reply #4 on: 07 November 2007, 22:57 »
if you want a remote feed, for an amp. from a manufacturer HU whack the blue wire from the amp onto the switched live to the HU, this will be the red or yellow wire at the back of the HU, try both.
if you get the wrong one the amp will stay on constantly, so use the other one and it should be sound!
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« Reply #5 on: 17 November 2007, 01:27 »
so let me understand...your tryin to hook up an amp to a factory fitted radio???
i would advise to use a multimeter to check an output feed from the headunit when it is on. find all the power supplies (11-12volt readings) chek them all when the radio is on and running....then turn the radio off from the radio only (NOT from the ignition) and power supply that you have lost from any of the ones you will have chekd is the wire u want to patch you blue remote lead to:-)
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
