Author Topic: ABF into MK2 16V........................  (Read 2658 times)
Offline Conker
Re: ABF into MK2 16V........................
« Reply #10 on: 18 January 2008, 11:14 »
Get your Injectors Ultrasonically cleaned! about 18 quid a shot with new rubbers and seals Injectors come in at over £40 each new!
There is a guy on ebay sells brand new brass merc injectors that are awesome and currently cost £18.50 each.
Link:  http://stores.ebay.co.uk/LR-SPARE-PARTS
Offline dTEA
  • back in an MK5
« Reply #11 on: 25 January 2008, 17:37 »
apparently thats what the geezer did to mine beforehand...but ummm not really noticing the diff in the standard 1.8 lump.
Edition 30 / T5 T32 Kombi
« Reply #12 on: 28 January 2008, 12:43 »
that bit is the oil filter housing, the oil cooler is part 11. always worth putting a new on on, they fail and fill the coolant woith oil, which is not nice.
Yopu can use the MK3 rack, just have to put MK2 track rods on it, and use the MK3 UJ as the MK2 one wont fit.  The MK3 pedal box wont fit well, the servo is different!   If i wre you id use your old MK2 gearbox, much less hassle!  I've also never seen any evidence that using the MK3 subframe actually drops the engine at all, though the mounts are beefier.
