Author Topic: Overheating  (Read 1797 times)
Offline BradHarris
Overheating
« on: 11 October 2007, 12:05 »
Anyone had overheating problems with the GTI whilst stood in traffic for more than 15 minutes or so ?
Happened a couple of times now, first in Edinburgh at easter - RAC guy said coolant resevoir cap hadn't been closed fully - not impressed. Then again the other day - temperature started creeping up 100. This time I put the fan and heater on full blast before the warning light came on and the temperature came down very quickly. Tested it on the drive and neither fan were cutting in for more than a few seconds before switching off again - temperature gradually crept up again.
Driving normally, temperture indicates a rock solid 90 degrees all the time.
Now booked into dealer next week for inspection.
Anyone else had this problem ?
Black 5dr, DSG, 18" Monza's, Leather, Ipod, MFSR, Highline, Winter + Lux packs.
Offline joesgti
Re: Overheating
« Reply #1 on: 11 October 2007, 15:44 »
nope, always sat at 90, probably just somthing to do with the fan  :sad:
GTI MK5
Not the only GTI...........but the best! ; )
Offline AlanD
  • MK5 2.0T 16v
Re: Overheating
« Reply #2 on: 11 October 2007, 15:55 »
Someone a while ago on here had problems with the their fans, can't remember who now.
I'm sure VW will sort you right out.
DannyBoyR32
Re: Overheating
« Reply #3 on: 11 October 2007, 16:25 »
should be simple to sort out
Phil mcavity
Re: Overheating
« Reply #4 on: 11 October 2007, 16:46 »
was the fan running with the air-con turned off, as it sounds like the overheat fans running 24-7 but turns out it was the air-con pump that made me think there was a fault but wasnt
Offline BradHarris
Re: Overheating
« Reply #5 on: 11 October 2007, 21:21 »
You're right Phil, I thought the intermittent nosie might have been the radiator cooling fans cutting in but that was the air con system. The radiator cooling fans are so quiet that you probably can't hear them at all when you're in the car (especially when they ain't working !!)
Phil mcavity
Re: Overheating
« Reply #6 on: 12 October 2007, 08:19 »
cool. glad thats fixed your problem.  :wink:
Offline BradHarris
Re: Overheating
« Reply #7 on: 17 October 2007, 00:04 »
Dealer had the car yesterday and said one of the fans needed replacing although the "memory" had not recorded any faults during operation. Said they'd run it up and tested and all OK. Haven't had chance to verify. Explicitly told them not to wash the car and guess what...
Offline 08micsta
  • 1982 Mini 1275 Clubby
Re: Overheating
« Reply #8 on: 17 October 2007, 10:24 »
They didnt clean it?  :rolleyes:
Wish for thinking........  :undecided:
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline gazbutmk5gti
Re: Overheating
« Reply #9 on: 17 October 2007, 20:47 »
Had both fans replaced on my 55 plate GTi, but for the opposite, they were running all the time, but there is known fault with them
Revo stg2+ & lots more
