Author Topic: Idle on a 8v gti...  (Read 2331 times)
Offline dabill
Idle on a 8v gti...
« on: 04 October 2007, 11:45 »
howdie..
2ltr 8v gti, fast cams and machined b/e..
before any one says use the search function i have... so there!
right, start the car and it fires up everytime, idle is fine, until my oil temp hits 100degrees, then i get erratic idle, car is lumpy and horrible when sat, and the oil like flicks on everynow and again, but as i say, until its warm, not a problem... except sometimes the revs stick at around 1100rpm at idle.
car admittedly needs a tune up, and tappets need doing, but other than that, cant see any air leaks but not sure where to look, and its had a new blue temp sender, oil pressure sensors...
any ideas anyone? should i start with cleaning the ISV with carb cleaner? or could it be the MAF?
i understand the fast cams will cause a certain amount of lumpy idle, but its defiently getting worse...
cheers
rob
noble tuned - and still not fast enough!
Offline Organisys
  • Old and Slow...
Re: Idle on a 8v gti...
« Reply #1 on: 04 October 2007, 12:26 »
If it's a Digifant, have you tried to replace the blue temp sender?
Offline dabill
« Reply #2 on: 04 October 2007, 12:43 »
i have done, but how do you check if its working propperly? is it run it upto temp, then unplug and see if it makes any difference?
Offline Richardali885
« Reply #3 on: 04 October 2007, 14:59 »
what's the water temp like cus 100degrees(for oil) is a bit hot mine neva goes over 94.??
how old is oil/filter.?
have you checked oil pressure switch.?
do you have a oil cooler.? is it blocked.?
or it could be an faulty idle valve.?
Offline dabill
« Reply #4 on: 04 October 2007, 15:35 »
haha, peaks at about 114 degrees for oil, but water never gets above just below 1/2... cooler might be shot...
oil filter is nearly new, had a change about 2 months ago. had new pressure switches (admittedly from euro car parts, but only cos the stealers guy is a spaz. and im gonna clean the isv out this weekend.
where is the idle valve located? and are they simple/cheap to change/fix?
Offline Mew
« Reply #5 on: 04 October 2007, 17:56 »
I wouldn't say 100 degrees for the oil is hot tbh. The highest mine got last night was 106 degrees and that was doing a ton for 20 minutes!
« Reply #6 on: 04 October 2007, 19:13 »
true but thats while driving, anyway
check out
http://cgi.ebay.co.uk/VW-GOLF-MK2-idle-speed-control-valve_W0QQitemZ180164582798QQihZ008QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(this not me just for you to see what you're looking for)
mk2/3 golf's use the same part. on a mk2 1.8, it's located on the rocker cover prob the same on a 2.0 with digi injection.
if it's working, with the bonnet open put hand though window N turn ignition on(all lights) and you should hear it click on, if not check wiring as connector may be corroded or a broken wire or faulty unit..?????
or you could just unplug connector whilst running idle. (LOL)
Offline dabill
« Reply #7 on: 04 October 2007, 19:18 »
right then, jus had a go at cleaning the isv, checked it was working before, by switchin ignition on, and touched it and could feel it vibrating slightly... so, off it came and had a good spray with carb cleaner...
put it all back together and it was still buzzing with ignition on... so fired er up and still not so ggreat idle... i unplugged the isv while the car was idleing and nothing happend at all, carried on with crappy idle... should it have made a difference?
bit confused now...
rob
Offline Organisys
  • Old and Slow...
« Reply #8 on: 04 October 2007, 20:35 »
Yes.
tomo320
« Reply #9 on: 04 October 2007, 23:39 »
take a pic of engine. be a good start.
