Author Topic: The latest Problem with my golf  (Read 1980 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
« on: 02 March 2004, 22:24 »
Hi I thought i'd let you all know the latest problem i'm having and see if anyone can shed some light on it.  I have just had my water pump and thermostat housing replaced at the garage because it was leaking.  I'm driving along and it all seems to work pretty fine, however, after 60 miles theres a funny sort of fishy smell which later dissapears, after a further ten miles the heat from the heater seems to start cooling down and the coolant guage on the dashboard goes down to its start position and stops working.  The oil temperature which normally operates around about 80 degrees will not increase past 60 degrees.  After a further 50 miles, the car gets slightly hotter for five minutes and the coolant temperature indicator moves very slightly and then it all goes to crap again.  I was just wondering if anyone could please, please, please explain this.  Once again your help is more than appreciated
thx
ps the car does blow lukewarm air out on its hottest setting but it is nowhere near as hot as it blew out before
regards
Marc
« Last Edit: 03 March 2004, 00:37 by marcogolfo »
Offline davidhawkins_78
  • Valver Bad Boy
Re:The latest Problem with my golf
« Reply #1 on: 04 March 2004, 15:18 »
Have you check your heater matrix - sounds like that's not right ...
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline richandhazel
« Reply #2 on: 04 March 2004, 17:33 »
Just wondering if they ran the car until the thermostat opened after changing the pump and thermostat. Could simply be a case that the coolant needs topping up. If its not that, then maybe an airlock, in which case try loosening one of the heater hoses jubilee clips at the highest point and see if coolant or air escapes.......careful not to burn yourself.
Blue MK2
« Reply #3 on: 04 March 2004, 18:26 »
i had that fishy smell. Once the coolant water was changed and the system was flushed it went away :-\
Offline marcogolfo
« Reply #4 on: 04 March 2004, 19:06 »
thx rich i'll try loosening the top hose and try and get rid of some air, should i do this with the engine running?  Also is it possible that if the thermostat was never put back in when the pump and housing was changed these effects would occur??
Blue MK2
« Reply #5 on: 04 March 2004, 19:19 »
your thermo is probably put back and is stuck open? ???
new thermo. ?14 from VAG :o
Offline marcogolfo
« Reply #6 on: 04 March 2004, 19:26 »
ya reckon??? cheers man, think i saw one at europarts for a fiver tho
thx
marc
