Author Topic: rust comming through from under windscreen seal, whats the best way to sort it  (Read 6826 times)
Offline hobbiniho
bite the bullet mate do it now and do it propperly and you will never have to worry again  :grin:
Offline BobbyT
theres some stuff you can get that turns rust back into metal, once you have cleaned the worst of it off paint that on and it should never return as long as its painted properly ill see if i can find a link to it  :cool:
do you know what this product is called?  :smiley:
Offline dabill
hammerite Krust... chemically reacts with the rust and makes it suitable for painting again, but again, it its rotted all the way through and its not just surface rust, then best plan is welding in new bits...
rob
noble tuned - and still not fast enough!
Offline Uruk Hai
The best thing all round on a car that nice is to get the screen out, cut out all the rust and if possible a extra 5 or 10 mm of the good metal to be sure you got it all and then have new metal welded in, not cheep but the best way IMO  :smiley:
Offline ...joe
well said that man!
stop being a tight arse and get it sorted properly! :laugh:
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline hobbiniho
and once you have welded a new patch in treat it with the rust remedy stuff just to be sure  :grin: :grin:
Offline BobbyT
well going to pop the screen and get it welded! on the cheap mind!  :wink:
Offline Uruk Hai
If you can put up some pics of the finished job  :smiley:
