Author Topic: rust comming through from under windscreen seal, whats the best way to sort it  (Read 6825 times)
Offline Uruk Hai
I've used that and it aint that good IMO  :sad: I used it and was only any good when I completely ground out every spec of rust and by then it was just acting as a primer for the rust free area left behind. I think the best long term policy is to cut out/grind every bit of rust possible/visible and then weld or fill the area followed by a rust preventing primer !
« Last Edit: 23 September 2007, 18:30 by Uruk Hai »
Offline hobbiniho
it was only a couple of months ago that i used it and the rust hasnt come back yet thats not saying that it wont, i hope it doesnt though  :cool:
Offline Uruk Hai
I hope the rust doesnt come back and to be fair you may just have done a better job than me  :smiley:
Offline e11ie
por-15 claim to "turn rust back to metal"....I'm a bit septical though
I'd say grind it out n filler it up  :smiley:
Offline hobbiniho
failing that dont forget to use good acid etch primer  :cool:
Offline BobbyT
Offline Horney
Deffo a glass out job. You'll find the area under the rubber has probably turned to dust. I would suggest getting it done now rather than leaving it as the worse it gets the more it'll cost.
Nick
Offline Mew
Good luck!
The mk2 i'm breaking had a bit of rust there, didn't look as bad as that though. When i took the windscreen out i found out that there was no metal behind it! :shocked:
Offline BobbyT
great!  :sad: oh well!
