Author Topic: MK3 cutting out  (Read 2434 times)
Offline alzabal
MK3 cutting out
« on: 02 March 2004, 12:06 »
Hi
can anyone help with a problem. I have had my MK3 GTI 2.0 ltr P reg for 3 months, just recently it cuts out without warning. This maybe happens once a week and at any speed eg at a roundabout and on the duel carraige way just yesterday.
The engine just dies but start on first turn of the ignition.
thanks for any help
Alan
Offline LadyCruzer
Re:MK3 cutting out
« Reply #1 on: 02 March 2004, 14:45 »
Theres a post on here... must be about 8 pages long about mk3s cutting out. Theres various problems and resolutions on there so take a look  ;D
Offline moffatcam
Re: MK3 cutting out
« Reply #2 on: 02 August 2009, 09:16 »
Try cleaning out the throttle chamber.
Offline VR6_Wherry
Re: MK3 cutting out
« Reply #3 on: 03 August 2009, 10:09 »
I have the exact same problem and have yet to find the soloution :( I'll keep you posted if i find the answer!
Offline robz
Re: MK3 cutting out
« Reply #4 on: 03 August 2009, 11:24 »
have a search on here, theres thousands of threads on this as it happens alot - including mine atm!! lol
plenty of info to be had!
gtigolfthree
Re: MK3 cutting out
« Reply #5 on: 03 August 2009, 11:32 »
My 8 valve starts at 1400 rpm then drops to 900rpm when warm and never cuts out touch wood. :smug:
Offline Khare
  • The bear that khares
Re: MK3 cutting out
« Reply #6 on: 03 August 2009, 11:33 »
that's helpful  :rolleyes:
Offline robz
Re: MK3 cutting out
« Reply #7 on: 03 August 2009, 11:49 »
lol, i thought it was meant to run like that  :grin:
Re: MK3 cutting out
« Reply #8 on: 03 August 2009, 11:50 »
thats normal.
Offline Xiled50
Re: MK3 cutting out
« Reply #9 on: 04 August 2009, 00:06 »
I had this on my Mk3 Driver. Tried loads and loads of things but in the end I cleaned out the fuel tank as I found there was some sediment in there and it never happened again. I couldnt tell you if that's coincidence but it's free and easy so you want to start there. Also clean and check every connection. It is a nightmare one though. Mine would do it then be fine 30 mins later.   :angry:
