Author Topic: heater surround led replacement  (Read 889 times)
Offline monkeyalan
« on: 18 September 2007, 15:58 »
right, i've got the grey backing off and have pulled the black bulb holder and bulb out.
now what?
can you buy a replacment bulb ?
heres a close up
cheers
« Last Edit: 18 September 2007, 16:12 by monkeyalan »
Offline bomp
Re: heater surround led replacement
« Reply #1 on: 18 September 2007, 18:10 »
Myself and others have bought these in the past http://www.ultraleds.co.uk/single-blue-10000-with-resistor-attached-p-750.html?osCsid=e64d116ba8dc64c2a6e554667652b9b6
Some other help maybe http://www.vintagewatercooleds.com/tech/Techtips/ATStechnotes/clusterlights/clusterlights.htm
I drilled small holes through the black plastic, for the LED legs to go through the other side, then soldered them to the blades. Snip the LED legs where they just get through or you might find it hard to put the blades back on.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline monkeyalan
« Reply #2 on: 18 September 2007, 18:17 »
cheers mate.  :wink:
Offline takethefifth
« Reply #3 on: 18 September 2007, 18:54 »
I bought a replacement from VW which i think was under a quid. Keeps it a nice simple swap!  :smiley:
Offline monkeyalan
« Reply #4 on: 18 September 2007, 19:19 »
whats replaced tho' the bulb and holder?
everything i try to get from VW is bloody obselete!  :angry:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #5 on: 19 September 2007, 01:41 »
You can place it with the pins sticking up and actually push the pins out, or is it pull them i forget which way i went with it now, but i did that then soldered the bulb onto the contacts ad put it back in, infact i thikn i pulled the legs out, then fed the bulb down thru, sodlered and refitted it, somehow.. sorry its vague  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
