Author Topic: Headunit resets itself  (Read 2872 times)
Offline dynamix
« on: 17 September 2007, 17:10 »
I've just wired in a new head unit into my MK3, but annoyingly it resets itself every time I turn the ignition off (so CDs start from the begggining, its forgets my settings etc). Any ideas what wire I've left out? It's a Kenwood CD player, and other than this problem it all works fine.
Offline andydavey
Re: Headunit resets itself
« Reply #1 on: 17 September 2007, 17:55 »
Swap the red and yellow wires on the loom coming from the headunit around.
Offline Uruk Hai
« Reply #2 on: 17 September 2007, 17:58 »
It would appear that the permanent live isnt connected or its connected to the ignition live which would cause the unit to lose all memory of settings and radio stations as soon as the ignition is off, establish which is the permanent and which one is the ignition and then connect them accordingly.  :smiley:
Offline dynamix
« Reply #3 on: 17 September 2007, 18:10 »
Thanks guys, will take a look at it now.
Offline dynamix
« Reply #4 on: 17 September 2007, 20:33 »
This is exactly what it was, swapped them around and problem solved, cheers!
taxiboy
« Reply #5 on: 18 September 2007, 15:11 »
:wink:
