Author Topic: Does anyone have a cold airbox fitted? Results?  (Read 12716 times)
Offline RedRobin
Re: Does anyone have a cold airbox fitted? Results?
« Reply #10 on: 17 September 2007, 14:27 »
looks sweet though!!!
ok next question.... exhaust systems - has anyone gone turbo back yet? im assuming a full system would start to make a 2L sound similar to an R32.
....It was my first mod. I felt the standard GTI was too quiet from inside - I like to hear the engine of any vehicle I drive.
An R32 is V6 and a 4-pot will never sound like a V6!! However, when working harder the Milltek Hi-flow (aka Turbo-back) sounds very good indeed. They take at least 1,000 miles to mature their sound. I've done about 35,000 miles on the Milltek Non-Resonated exhaust. The Turbo-back is the one above in the pic:
Offline joesgti
« Reply #11 on: 17 September 2007, 14:39 »
so how much bhp would you see from this system? also how loud is it, it dosnt sound chav does it?? :sick:
GTI MK5
Not the only GTI...........but the best! ; )
Offline Teutonic_Tamer
« Reply #12 on: 17 September 2007, 14:42 »
T_T - The Carbonio channels a significantly bigger volume of air to the filter as it has none of the compartments inside that the stock intake has. It's also bigger and has a more curvy flow.
Having said the above, I don't know enough about the physics to say that any of this matters, but I have seen dyno plot comparisons which seem to show that the Carbonio does offer improvements.
The actual Carbonio itself may be larger than the original intake, but yours is still connects to the OEM airbox, and there are other restrictive components beween the air intake and the combustion chambers.
There are a few other sites within the air intake system which can provide restrictions.  On some cars, it is normally inside the airbox where restrictive sound deadening baffles are placed.  If you know where to look, you can sometimes modify them yourself (indeed, I was doing this very mod on Mk4 Astra airboxes long before a highly regarded Vauxhall tuner, Courtenay, started charging for an identical mod  :smug: ).  However, the GTI airbox, which looks identical to the S3 doesn't seem to be too restrictive.
Other areas of restriction can be the intercooler (though this seems OK, as it is also used on the Ed30 and Leon Cupra), the MAF, the turbo (definately an area of restiction, as the Ed30, Cupra and S3 all have a larger turbo), the inlet manifold, and finally the intake valves.
I feel like a homo
« Reply #13 on: 17 September 2007, 14:46 »
Ohhh - I notice that doesn't have the close coupled primary cat.  The Bosch MED9 uses a "homogen" split to calculate fuel delivery, which relies on pre and post cat lambda probes.  Does/did this throw any error codes on yours?
I feel like a homo
Offline RedRobin
« Reply #14 on: 17 September 2007, 15:03 »
....No error codes have ever been thrown in 35,000 miles. :smiley:
« Reply #15 on: 17 September 2007, 15:16 »
OK, thanks.
Does the Milltek still have the upstream boss fitting for the pre-cat lambda?  The blue circles are for the main or post-cat lambdas, and the pink circle is for the pre-cat lambda, but I can't see the boss on the Milltek?
I feel like a homo
Offline RedRobin
« Reply #16 on: 17 September 2007, 16:06 »
OK, thanks.
....They are both Milltek - the one below is a Cat-back. I'm afraid that you've completely lost me re terms such as pre and post-cat lambdas.
Offline TagnuT
  • Edition 30
« Reply #17 on: 17 September 2007, 21:52 »
Red Robin I think that your Carbon Cam Cover looks very nice indeed.
Bye Bye Edition 30
Offline TagnuT
  • Edition 30
« Reply #18 on: 17 September 2007, 21:53 »
Looks like a OSIR design piece of work to me. They do some nice stuff. :cool:
Bye Bye Edition 30
Offline El_Christie
« Reply #19 on: 17 September 2007, 22:25 »
Yes it does in deed...  :wink: .... Could you please gimme details on the Carbon Cam Cover... wea did u purchase this item??
