Author Topic: Temperature  (Read 2117 times)
Offline JMallows
Temperature
« on: 28 February 2004, 19:14 »
Hi, on my 1.3 golf the temperature gauge has never worked properly, only very occasionaly does it work. I don't even know where this is located, anyone got any ideas on how to fix it? Could it be a loose wire, as its intermittent?
A clever person solves a problem. A wise person avoids it.
turbo
Re:Temperature
« Reply #1 on: 01 March 2004, 14:52 »
it is located in the thermostat housing which is on the righthand side of the cylinderhead. its a little thing with 1 wire conected to it . it may be a loose conection. if you have the haynes manual it tells you in this it has a pic of where its located. its in the cooling section.... :)
if this wire is on ok then it could be the sender if you replace it and it still doesnt work then it may be the loose wire connections at the back of your clocks....
but it will either be faulty sender or loose conection on the sender....... hope this helps
Offline JMallows
Re:Temperature
« Reply #2 on: 01 March 2004, 21:39 »
Yeah, thanks. I'll have to try that. Do you know where i can get a new one and how much, or is it one of those thongs that everyone stocks? How easy is it to replace too?
Veedubgt18v
Re:Temperature
« Reply #3 on: 02 March 2004, 11:55 »
i wish everyone stocked thongs  ;)  you will have to go to vw i recently bought an oil temp sender from them and it was just over a tenner
turbo
Re:Temperature
« Reply #4 on: 02 March 2004, 14:18 »
just slide the wire off then get a little spanner to undo it unscrew it out screw the new one back in slide the wire back on it and hey presto perfect working temp guage! ;D
Offline JMallows
Re:Temperature
« Reply #5 on: 03 March 2004, 17:24 »
Oops, missed the "i" and got the "o" instead!!  ::)
Thanks everyone, i'll have to go and try that.  ;)
