Author Topic: mk3 stalks on mk2  (Read 1887 times)
Offline ASH
  • its a way of life!
mk3 stalks on mk2
« on: 28 February 2004, 18:05 »
has anyone done this, if so how did you get the trim round the cloum to fit?
Offline ASH
Re:mk3 stalks on mk2
« Reply #1 on: 29 February 2004, 17:47 »
has nobody done this?
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 29 February 2004, 19:32 »
I have the opposite. mk2 stalks with mk3 ignition surround. small trimmings around the bottom, but the rest fits fine
the only think you'll need to do is make the hazard switch hole bigger as the mk3's is about 3 times the size of the '90 spec mk2 switch.
Mk4 Golf 150PD
« Reply #3 on: 01 March 2004, 13:38 »
Its a straight swap as long as you have the late 'central electric' version with the hazard switch on the top of the stalks.  Don't worry about having to make the hole for the hazard switch bigger, as you can just swap the switches round and use the MK2 switch with the MK3 stalks.
Or you could fit the MK3 ignition cowling, then the dashboard, then the brakes, might as well fit the engine too while you're at it ;)
Offline ASH
« Reply #4 on: 02 March 2004, 19:43 »
so just swap ther red lense caps over, does it just pull off?
« Reply #5 on: 03 March 2004, 10:03 »
As far as I know it just clips off, can you remove the cowling on yours and give it a try before you buy more stalks?
Offline GTIMKiiJODE
« Reply #6 on: 04 March 2004, 23:13 »
Nicelooking wheels. Are they bbs and where did you get them. look sweet.
Offline ASH
« Reply #7 on: 05 March 2004, 13:58 »
bbs rm's 7 inch wide, soon to be eight ;) i know a set for sale if anyone is interested
Offline GTIMKiiJODE
« Reply #8 on: 11 March 2004, 14:57 »
Definately interested if they still for sale and how much please. E-mail at jodywelton@talk21.com. I have got bbs wheels on my golf bot they are a bit worst for ware and only 14". Lost a wheel centre off one aswell. Really interested so let me know. Cheers mate.
Offline sidecarphil
Re: mk3 stalks on mk2
« Reply #9 on: 21 April 2009, 18:47 »
can i fit MK3 stalks to a MK2 with the hazzard light switch on the dash ???
if so how ??
