Golf mk2
mk3 stalks on mk2
Topic: mk3 stalks on mk2 (Read 1886 times)
jamrock
Guest
Re: mk3 stalks on mk2
Reply #10 on:
21 April 2009, 22:48 »
Quote from: sidecarphil on 21 April 2009, 18:47
can i fit MK3 stalks to a MK2 with the hazzard light switch on the dash
if so how ??
also interested...
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #11 on:
22 April 2009, 09:35 »
not directly no, the elctrical plugs are different, as is the ignition lock surround, and the ign switch. Oh and the entire steering column tube too, though you can get away with grinding the lug off but not what i would recommend.
sidecarphil
Reply #12 on:
22 April 2009, 17:30 »
so jon it needs a lot of MK3 parts
can i not use a mk2 column with mk3 ign switch and stalks
rubjonny
10k hero
Reply #13 on:
23 April 2009, 10:16 »
sorry should have been more clear!
MK2 90spec column tube, ign lock housing and switch. The lock housing and switch is same between MK2 & MK3 tho, but the outer column tube you want is a MK2 90spec one.
Golf mk2
mk3 stalks on mk2
